  3. Remove design variable "(name=value)" pairs in ViVA waveform...
  • Views 3740
Remove design variable "(name=value)" pairs in ViVA waveform names
MatthewLove
MatthewLove over 7 years ago
When I plot waveforms in ViVA, sometimes variables are included next to the waveform names in brackets.
Is there a way to disable this?
It makes the waveform name excessively long.
I've included an example below.
    Andrew Beckett over 7 years ago in reply to MatthewLove +1
    You didn't mention the subversion (you just specified the major version - which IC617 hotfix is it? Help->About will tell you). I don't see this behaviour (I repeated your steps) in IC617 ISR22 (IC6…
    I see the same problem with that sub-version. I'd suggest moving to a newer subversion since that was definitely in the early days of Explorer/Assembler and there have been a lot of improvements since…
    How are you plotting the waveform? Which IC subversion are you using? I'd like to reproduce this first to make sure that I'm reproducing exactly what you're seeing.
  • MatthewLove
    MatthewLove over 7 years ago in reply to Andrew Beckett
    Thanks for the reply.
    I'm on 6.1.7-64b.
    To recreate the issue I did the following steps:
    • I made a circuit with an ideal capacitor C (from analogLib) in series between two ports (image #1 below).
    • In ADE Explorer, I set up an S-parameter simulation from 1G to 10G with C=1 pF (image #2).
      • Everything else was left default.
    • The results (S11, S22, S21) are plotted in ViVA
      • The variable C is not printed next to the waveform name.
    • I then swept C from 1 pF to 2 pF and plotted the results.
      • Each wave is on a separate graph in ViVA (image #3).
    • I changed C back to a static value of 1 pF and repeated the simulation.
    • C is now printed next to each S-parameter result (image #4 below)
    Matthew
    I don't see this behaviour (I repeated your steps) in IC617 ISR22 (IC6.1.7-64b.500.22).
  • MatthewLove
    IC6.1.7-64b.500.4
    Thanks for looking into it anyway.
    I see the same problem with that sub-version. I'd suggest moving to a newer subversion since that was definitely in the early days of Explorer/Assembler and there have been a lot of improvements since then.
  • MatthewLove
    Thanks Andrew. That's good to know.
