  3. edit schematic annotation will freeze the whole cadence...
  • Replies 7
  • Views 18182
edit schematic annotation will freeze the whole cadence session until I xkill it
monglebest
monglebest over 7 years ago
I am using Cadence Virtuoso IC6.1.7-64b.500.21 with ADE-L.
I find it in multiple cases that when I open view->annotations->Setup and try to add more DC Operating Points, the whole cadence session will be freezon. I come back the next morning, it is still hanging there. I have to kill it. Is this a bug?
    Andrew Beckett over 7 years ago +1
    I know there were some issues with annotation caching in some of the IC617 ISRs which were improved in ISR23. So please check with 6.1.7.500.23 and if it's still there in ISR23, please contact customer…
    I know there were some issues with annotation caching in some of the IC617 ISRs which were improved in ISR23. So please check with 6.1.7.500.23 and if it's still there in ISR23, please contact customer support.
    I'm not sure it's necessarily going to resolve what you're seeing, but please check the latest hotfix version first.
    Kind Regards,
  • monglebest
    monglebest over 7 years ago in reply to Andrew Beckett
    Tried version 23 with the help from CAD, it seems work for me.
  • monglebest
    still very slow. I type in the value, wait for 30 seconds to have the annotation window to response. Current version is IC6.1.7-64b.500.23. Once the annotation window is responding, the rest of Cadence windows are all hanging.
    Andrew Beckett over 7 years ago in reply to monglebest
    In that case you really need to contact customer support as I advised above. Initially you said it worked, so presumably something is different (maybe the circuit is a lot bigger, or you're running post-layout)?
  • monglebest
    It's very simple schematic only circuit for current mirror. The annotation feature works a while and then freezes. I don't know when it will freeze or start to hang. There is no post-layout or more complex circuit involved. Maybe I have too many adel and adexl windows opened?
    No idea - that's why I'm suggesting contacting support as then we (Cadence, not necessarily me) can look at it together and run some diagnostic tests potentially.
  • monglebest
    Case Number: Case 46355308
