  3. Input Capacitance Characterization in Cadence Liberate
  • Replies 26
  • Subscribers 132
  • Views 36667
anurans
anurans over 7 years ago
Hi All,
I have a transistor level description of a custom standard cell which is made of pass transistors and transmission gates.
As can be seen, since the input buffering (i.e. an inverter) is missing (i.e. input B) in this type of a cell, the input capacitance seen at B input depends on the capacitive load presents at the output. How can we indicate this to Liberate and make the input capacitance of the cell a function of output load capacitance instead of a fixed value ?
Thanks in advance
Anuradha
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to anurans
    if you are not using -auto_index option, then this index-1 table comes from your own definition. Please check your define_template command for this template.
    Guangjun
  • anurans
    anurans over 6 years ago in reply to Guangjun Cao
    Unfortunately not ! That's the strange thing here. Here's my definition for index-1/2 tables :
    define_template -type delay \
    -index_1 {0.002 0.0120375 0.0472711 0.114555 0.21938 0.366461 0.56 } \
    -index_2 {0.001 0.0017421 0.00434703 0.00932152 0.0170715 0.0279457 0.0422546 } \
    delay_template_7x7_1043
    define_template -type power \
    power_template_7x7_1043
    I don't see the same index-1 table in the generated .lib file as I've shown earlier.....
    Anuradha
  • Guangjun Cao
    this is odd. please file a support case. That is the only way I can look into this.
    guangjun
  • anurans
    Okay, but jut to confirm everything looks correct, can we directly assign a pre-define capacitive load like below to the output of the cell:
    //-------------------------------------------- In Harness file ------------------------------------------------------------
    //ONE_B and INT are the outputs of the cell, assigning 1 fF loads between each output and GND
    Coneb ONE_B_altos_out 0 1e-15
    Cint INT_altos_out 0 1e-15
    Or should the output load necessarily be from the index-2 capacitance values (If yes, I don't see a difference between non-harness/harness characterization, because the whole point here is to define a custom load) ?
    Thanks in advance
    Anuradha
  • Guangjun Cao
    Additional load can be added. it is quite common to to have a resistive load, eg. pull-up/down. For a capacitive load, you can either use a harness, or a wrapper subckt with the same cell/ports names as your original block (you need to rename the original subckt). Then, connect the C load as you want. In such a way, the C load is part of the cell to be characterized.
    Is this what you want?
    Guangjun
  • anurans
    I think that's already been done in my harness circuit (so what I did seems correct). Regarding the odd numbers in the .lib file, I have no idea why it happens. I will file a support case for that.
    Thanks for the inputs.
    Anuradha
