  3. How to fix *WARNING* The number of errors was detected in...
  • Replies 26
  • Views 46610
How to fix *WARNING* The number of errors was detected in Extract Tab: 1 in Calibre QRC run.
Marben
Marben over 7 years ago
Hi All,
I am trying to run Calibre Quantus QRC,
First I make a QRC command file name "tech.def".
Here is my code:
DEFINE pex_tech /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed
process_technology
-technology_library_file /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/tech.def
-technology_name pex_tech
-ruleset_name /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/lvsfile
But I have an error in CIW like this:
I also got an error in CIW like this.
Please help me.
Best regards,
Marben
  • Marben
    Marben over 7 years ago in reply to Quek
    Hi Quek,
    I asked in Mentor support.
    The error "ERROR(130): Incorrect MASK SVDB DIRECTORY options for this function." is gone affter
    adding "MASK SVDB DIRECTORY "svdb" QUERY CCI" to my LVS rule deck.
    And click the checkbox "Generate Calibre Connectivity Interface data"  in calibre Outputs tab.
    Then I click Run LVS and run query.
    I now have an spi file generated in my query output folder.
    But, still calibre qrc runs failed.
    Please help.
    Best regards,
    Marben
    Fullscreen 1651.qrc.r1.log Download
      Cadence Quantus QRC Extraction - 64-bit Parasitic Extractor - Version
    15.1.4-s005 Fri Nov 20 15:19:16 PST 2015
                                        Copyright 2015 Cadence Design Systems,
    Inc.
    WARNING (LBRCXM-624): Warning [input]: Line 6: 'well' statement is ignored in ICT file line.
    WARNING (LBRCXM-624): Warning [input]: Line 7: 'well' statement is ignored in ICT file line.
    INFO (LBRCXM-630): Starting extraction: Mon Mar 11 12:33:43 2019
    ERROR (AGDPRP-31003): can't open /home/marben/query_output/query_output/r1_pin_xy.spi
    INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
     agdsPrep -V -rundir /home/marben/query_output/query_output -outdir /home/marben/query_output/query_output/r1 -sch -e /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/layerSetupFile:r1.alm,r1.ilf -pl r1.ports -mcell /home/marben/query_output/query_output/r1/r1.hcl -l /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed/lvsfile -i r1.ixf,r1.lph,r1.sph:r1.gdx -n r1.nxf,r1.stl:r1.gnx -s r1_pin_xy.spi:r1.xcn,hccidtmfile
    Forking: agdsPrep -V -rundir /home/marben/query_output/query_output -outdir /home/marben/query_output/query_output/r1 -sch -e /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/layerSetupFile:r1.alm,r1.ilf -pl r1.ports -mcell /home/marben/query_output/query_output/r1/r1.hcl -l /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed/lvsfile -i r1.ixf,r1.lph,r1.sph:r1.gdx -n r1.nxf,r1.stl:r1.gnx -s r1_pin_xy.spi:r1.xcn,hccidtmfile
    ERROR (LBRCXM-633): Bad return status from RCX script generator. Status 256
    INFO (LBRCXM-709): *****  Quantus QRC terminated abnormally  *****
  • Marben
    Hi Quek,
    I copied Design_pin_xy.spi to r1_pin_xy.spi,
    The error "ERROR (AGDPRP-31003): can't open /home/marben/query_output/query_output/r1_pin_xy.spi" is gone.
    Here is now my error.
    ERROR (AGDPRP-31040): output_setup -net_name_space "SCHEMATIC" is not supported with extract-only data. Specify output_setup -net_name_space "LAYOUT" instead.
    Please help.
    Best regards,
    Marben
    Fullscreen 3771.qrc.r1.log Download
    Inc.
    INFO (LBRCXM-630): Starting extraction: Mon Mar 11 13:35:27 2019
  • Quek
    Quek over 7 years ago in reply to Marben
    Hi Marben
    Thanks for the update. Here are my comments:
    a. Now we know that your "MASK SVDB ..." cmd in the Calibre LVS deck was overwritten by the cmd which was generated by the Calibre LVS form. Thanks for solving the problem. The query output looks correct now
    b. In "Run Details" tab in Quantus form, the run name should be "Design" and not "r1". Would you please change it and re-run extraction?
    Best regards
    Quek
  • Marben
    Hi Quek,
    I replaced r1 to Design, but same error exist.
    Fullscreen qrc.Design.log Download
    Inc.
    INFO (LBRCXM-630): Starting extraction: Mon Mar 11 15:27:16 2019
     agdsPrep -V -rundir /home/marben/query_output/query_output -outdir /home/marben/query_output/query_output/Design -sch -e /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/layerSetupFile:r1.alm,r1.ilf -pl r1.ports -mcell /home/marben/query_output/query_output/Design/r1.hcl -l /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed/lvsfile -i r1.ixf,r1.lph,r1.sph:r1.gdx -n r1.nxf,r1.stl:r1.gnx -s r1_pin_xy.spi:r1.xcn,hccidtmfile
    Forking: agdsPrep -V -rundir /home/marben/query_output/query_output -outdir /home/marben/query_output/query_output/Design -sch -e /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/layerSetupFile:r1.alm,r1.ilf -pl r1.ports -mcell /home/marben/query_output/query_output/Design/r1.hcl -l /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed/lvsfile -i r1.ixf,r1.lph,r1.sph:r1.gdx -n r1.nxf,r1.stl:r1.gnx -s r1_pin_xy.spi:r1.xcn,hccidtmfile
    Please help.
    Best regards,
    Marben
  • Quek
    Hi Marben
    I think the error has already changed.Previously we had this error:
    This has already been resolved by setting "Run Name" as "Design"
    Now we have this error:
    This is really quite strange. Although we can resolve the error by using "Layout" namespace in "Netlisting" tab, it should not be necessary. It seems that you had executed Calibre using "calibre -lvs" and not "calibre -ext" and hence the data should not be "extract-only".
    Would you please file a case to Cadence support centre so that they can have a look at it?
    Quek
  • Marben
    Hi Quek,
    Thank you for your help and reply.
    I will file a case to Cadence support.
    Best regards,
    Marben
