  3. How to fix *WARNING* The number of errors was detected in...
  • Replies 26
  • Views 46598
How to fix *WARNING* The number of errors was detected in Extract Tab: 1 in Calibre QRC run.
Marben
Marben over 7 years ago
Hi All,
I am trying to run Calibre Quantus QRC,
First I make a QRC command file name "tech.def".
Here is my code:
DEFINE pex_tech /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_FuncCmax_Detailed
process_technology
-technology_library_file /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/tech.def
-technology_name pex_tech
-ruleset_name /home/marben/Desktop/Components/Calibre/PARASITIC/CMOS55LPE_5_00_01_00_LB/CMOS55LPE_5_00_01_00_LB_Nominal_Copied_Detailed/lvsfile
But I have an error in CIW like this:
I also got an error in CIW like this.
Please help me.
Best regards,
Marben
  • Quek
    Quek over 7 years ago in reply to Marben
    Hi Marben
    Except for the missing Design_pin_xp.spi file, your query output looks quite ok. Does your Calibre LVS rule deck contain the following cmd?
    MASK SVDB DIRECTORY svdb CCI
    If not, would you please add it, re-run LVS and then re-run query? if it still does not work, you need to work with Mentor AE first to find out why the file is missing.
    Best regards
    Quek
  • Marben
    Marben over 7 years ago in reply to Quek
    Hi Quek,
    My calibre rule deck don't have the command " MASK SVDB DIRECTORY svdb CCI",
    I already added it in my LVS rule deck, but
    same errors exist.
    Can you remote control in my machine using Anydesk or teamviewer?, so that you can assist me.
    Best regards,
    Marben
  • Quek
    Hi Marben
    It seems that the query log file already tells us that the query did not went well:
       gds         write                      query_output/Design.agf
       ERROR(130): Incorrect MASK SVDB DIRECTORY options for this function.
       layout      nametable   write          query_output/Design.lnn
       layout      netlist     write          query_output/Design_pin_xy.spi
    I made a mistake in the cmd. It should be "MASK SVDB DIRECTORY svdb QUERY CCI". Would you please add the word "QUERY" and try again?
    Best regards
    Quek
  • Marben
    Hi Quek,
    I already add the "QUERY" in my calibre lvs rule file.
    Fullscreen rule_deck.txt Download
    #! tvf
    namespace import tvf::*
    VERBATIM {
    # GLOBALFOUNDRIES Singapore Pte. Ltd.
    # File:                 cmos55lpe.lvs.cal
    # Description:          Mentor Calibre LVS Runset for CMOS55LPE/RF Process
    # Document ID:          EDA-CAD-55N-LV035
    # Document Revision:    15
    # Author:               Raju Mani
    # Date:                 2016-07-31 21:32:43
    # Copyright (c) 2016 GLOBALFOUNDRIES Singapore Pte. Ltd.
    # This document is confidential and a proprietary product of GLOBALFOUNDRIES Singapore Pte. Ltd.
    # Any unauthorized use, reproduction or transfer of this document is strictly prohibited.
    # Disclaimer:
    # The information contained herein is confidential and is the property of GLOBALFOUNDRIES and/or
    # its licensors.  GLOBALFOUNDRIES reserves all proprietary, design, manufacturing, reproduction,
    # use, sales and other rights in the information herein, in its products and services, and to any
    # article or process utilizing such information, except to the extent that rights are expressly
    # granted to others.
    # This document is for informational purposes only, is current only as of the date of publication
    # and is subject to change by GLOBALFOUNDRIES at any time without notice.  While precautions have
    # been taken in the preparation of the information herein, it may contain technical inaccuracies,
    # omissions and typographical errors. GLOBALFOUNDRIES is under no obligation to update or otherwise
    # correct this information.
    # All information contained herein is provided "AS IS."  GLOBALFOUNDRIES makes no representations
    # and disclaims all warranties of any kind, express or implied, including without limitation any
    # implied warranties of non-infringement, merchantability or fitness for a particular purpose,
    # with respect to the information contained HEREIN.
    # Terms and conditions applicable to the purchase, quality and use of GLOBALFOUNDRIES' products
    # and services are as set forth in your organization's signed agreement with GLOBALFOUNDRIES or
    # in GLOBALFOUNDRIES' Standard Terms and Conditions of Sale.  Unless otherwise authorized in a
    # signed agreement with GLOBALFOUNDRIES, GLOBALFOUNDRIES' products and services are NOT intended
    # for use in applications such as implantation, life support, or other hazardous uses where
    # malfunction could result in death, bodily injury, or catastrophic property damage.
    # GLOBALFOUNDRIES, the GLOBALFOUNDRIES logo and combinations thereof are trademarks of
    # GLOBALFOUNDRIES Inc. in the United States and/or other jurisdictions. Other product or service
    # names are for identification purposes only and may be trademarks or service marks of their
    # respective owners.
    # � GLOBALFOUNDRIES Inc. 2015. Unless otherwise indicated, all rights reserved.
    # Do not copy or redistribute except as expressly permitted by GLOBALFOUNDRIES.
    VERBATIM {
    VERBATIM {
    // Header Section                                                    //
    // SWITCHES FOR THIS CALIBRE LVS DECK                                //
    // METALLIZATION OPTIONS                                             //
    // You MUST uncomment ONE metallization option.
    // For more information see Table 2-7, Preferred Metallization options, in the
    // Design Manual.
    //                  a = # of 1x Thin  layers
    //             	  b = # of 2x low-K layers
    // a_bc_de_fg:      c = # of 2x FTEOS layers
    //                  d = # of 4x low-K layers
    //                  e = # of 4x FTEOS layers
    //                  f = # of 12x TEOS layers
    //                  g = # of 12x FTEOS layers
    // Top Metal is always LB.
    // Uncomment 1 Metallization Option OR use environmental variable BEOL_STACK
    //#DEFINE 5_00_01_00_LB    //(M1, M2, M3, M4, M5, EA, LB)
    //#DEFINE 6_00_01_00_LB    //(M1, M2, M3, M4, M5, M6, EA, LB)
    //#DEFINE 4_02_00_00_LB    //(M1, M2, M3, M4, BA, BB, LB)
    //#DEFINE 5_02_00_00_LB    //(M1, M2, M3, M4, M5, BA, BB, LB)
    //#DEFINE 6_02_00_00_LB    //(M1, M2, M3, M4, M5, M6, BA, BB, LB)
    //#DEFINE 4_00_02_00_LB	   //(M1, M2, M3, M4, EA, EB, LB)
    //#DEFINE 5_00_02_00_LB	   //(M1, M2, M3, M4, M5, EA, EB, LB)
    //#DEFINE 6_00_02_00_LB	   //(M1, M2, M3, M4, M5, M6, EA, EB, LB)
    //RF-Only Metal Options
    //#DEFINE 5_00_01_10_LB		//(M1, M2, M3, M4, M5, EA, OI, LB)
    //#DEFINE 6_00_01_10_LB		//(M1, M2, M3, M4, M5, M6, EA, OI, LB)
    //#DEFINE 5_00_00_10_LB    //(M1, M2, M3, M4, M5, OI, LB)
    //#DEFINE 5_01_00_10_LB    //(M1, M2, M3, M4, M5, BA, OI, LB)
    //#DEFINE 6_01_00_10_LB    //(M1, M2, M3, M4, M5, M6, BA, OI, LB)
    //Alternative Metal Options
    //#DEFINE 5_01_00_00_LB		//(M1, M2, M3, M4, M5, BA, LB)
    //#DEFINE 6_01_00_00_LB		//(M1, M2, M3, M4, M5, M6, BA, LB)
    //#DEFINE 7_01_00_00_LB		//(M1, M2, M3, M4, M5, M6, M7, BA, LB)
    if [ info exists env(INCLUDE_FILE) ] {
            VERBATIM {INCLUDE $INCLUDE_FILE}
    } else {
    #        VERBATIM {INCLUDE $TECHDIR/LVS/sample_design.inc.cal}
    VERBATIM {
    #IFDEF $BEOL_STACK 5_00_00_10_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_00_01_10_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_00_01_10_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_00_02_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_00_01_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_00_02_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_00_01_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 4_00_02_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_02_00_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_02_00_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 4_02_00_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_01_00_10_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_01_00_10_LB
    #ELSE
    #IFDEF $BEOL_STACK 5_01_00_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 6_01_00_00_LB
    #ELSE
    #IFDEF $BEOL_STACK 7_01_00_00_LB
    #ELSE
           SVRF ERROR "\n\n\n\t  _____NO_VALID_METAL_STACK_OPTION_DEFINED_____  \n\n\n                                   \t\t  Valid options for BEOL_STACK are:               \n\n                                 \t\t\t  5_00_01_10_LB         \n\n                                 \t\t\t  5_00_00_10_LB                       \n\n                                \t\t\t  6_00_02_00_LB                                \n\n                                \t\t\t  5_00_01_00_LB                                \n\n                                \t\t\t  5_00_02_00_LB                                \n\n                                \t\t\t  6_00_01_00_LB                                \n\n                                \t\t\t  4_00_02_00_LB                                \n\n                                \t\t\t  5_02_00_00_LB                                \n\n                                \t\t\t  4_03_00_00_LB                                \n\n                                \t\t\t  6_02_00_00_LB                                \n\n                                \t\t\t  4_02_00_00_LB					\n\n				   \t\t\t  5_01_00_10_LB				\n\n				   \t\t\t  6_01_00_10_LB				\n\n				   \t\t\t  5_01_00_00_LB				\n\n				    \t\t\t  6_01_00_00_LB				\n\n				     \t\t\t  7_01_00_00_LB	                          \n\n  "
    #ENDIF // 7_01_00_00_LB
    #ENDIF // 6_01_00_00_LB
    #ENDIF // 5_01_00_00_LB
    #ENDIF // 6_01_00_10_LB
    #ENDIF // 5_01_00_10_LB
    #ENDIF // 4_02_00_00_LB
    #ENDIF // 6_02_00_00_LB
    #ENDIF // 5_02_00_00_LB
    #ENDIF // 4_00_02_00_LB
    #ENDIF // 6_00_01_00_LB
    #ENDIF // 5_00_02_00_LB
    #ENDIF // 5_00_01_00_LB
    #ENDIF // 6_00_02_00_LB
    #ENDIF // 6_00_01_10_LB
    #ENDIF // 5_00_01_10_LB
    #ENDIF // 5_00_00_10_LB
    VERBATIM {
    // SWITCHES - see documentation for description and proper usage     //
    //                     Custom Switches                            //
    // ***NOTE: Refer to the Calibre LVS release notes to learn how to
    //          set these new environmental variables.***
    // This option is used to not compare device properties.
    // Uncomment this option if you do not want property comparison.
    // Be careful using this.
    // If environmental variables are being
    // used, do NOT edit the next lines!
    // To enable/disable this switch please use the following
    // environmental variable:
    // $NO_TRACE_PROPERTY = TRUE/FALSE
    //#DEFINE NO_TRACE_PROPERTY
    #IFDEF $NO_TRACE_PROPERTY TRUE
    #ENDIF
    // This option is used to NOT compare FET nf property.
    // Use this option if you do not want nf property comparison.
    // Be carefull using this.
    // $CHECK_NUMBER_OF_FINGERS = TRUE/FALSE
    //#DEFINE IGNORE_NF_PARAM
    #IFDEF $CHECK_NUMBER_OF_FINGERS FALSE
    #ENDIF
    // This option is used to compare TIEDOWN DIODES tdndsx/tdpdnw
    // Area and Perimeter properties.
    // Use this option if you want A and perim property comparison. .
    // $CHECK_TIEDOWN_PARAM = TRUE
    //#DEFINE CHECK_TIEDOWN_PARAM
    #IFDEF $CHECK_TIEDOWN_PARAM TRUE
    #ENDIF
    // This option is used not to compare pccrit property of FETs or not.
    // $IGNORE_PCCRIT_PARAM = TRUE/FALSE
    // Hardcoded to TRUE because pccrit is not supported in the technology.
    #DEFINE IGNORE_PCCRIT_PARAM
    #IFDEF $IGNORE_PCCRIT_PARAM  TRUE
    #ENDIF
    // To run PEX, define "PEX_RUN"
    // To run LVS, do not define "PEX_RUN"
    // $PEX_RUN = TRUE/FALSE
    //#DEFINE PEX_RUN
    #IFDEF $PEX_RUN TRUE
      #DEFINE PEX_RUN
      #IFDEF $CORNERROUNDING TRUE
        #DEFINE CORNERROUNDING    // corner rounding is only valid when PEX_RUN is set to TRUE
      #ENDIF
    #ENDIF
    // To run ERC, define "ERC_RUN"
    // $ERC_RUN = TRUE/FALSE
    //#DEFINE ERC_RUN
    #IFDEF $ERC_RUN TRUE
      #DEFINE ERC_RUN
    #ENDIF
    // Series MOS reduction is not permitted by Default
    // Uncomment the switch below if user wants to reduce sreies MOS devices
    // $REDUCE_SERIES_MOS = TRUE/FALSE
    //#DEFINE REDUCE_SERIES_MOS
    #IFDEF $REDUCE_SERIES_MOS TRUE
    #ENDIF
    // Split gate MOS reduction is not permitted by Default
    // $REDUCE_SPLIT_GATES = TRUE/FALSE
    //#DEFINE REDUCE_SPLIT_GATES
    #IFDEF $REDUCE_SPLIT_GATES TRUE
    #ENDIF
    // LVS recognize RX FILL as RX drawing by default.
    // Uncomment the switch below if user wants to exclude RX FILL as drawing
    // $EXCLUDE_RX_FILL = TRUE/FALSE
    //#DEFINE EXCLUDE_RX_FILL
    #IFDEF $EXCLUDE_RX_FILL TRUE
    #ENDIF
    // By default,LVS use 2K high-Rs p+ poly resistor
    // To define 1K p+ poly resistor,please use the following environmental variable:
    //    $POLY_HIGH_RES =  [1K || 2K]
    //    e.g.
    //    setenv POLY_HIGH_RES 1K # [1K || 2K]
    // If environmental variables are being used, do NOT edit the next lines!                                 //
    // #DEFINE POLY_HIGH_RES_1K // Uncomment this line to extract 1K p+ poly resistor
    #IFDEF $POLY_HIGH_RES 1K
    #ENDIF // $POLY_HIGH_RES
    // Include files                                                     //
    // General calibre tool options which users are required to set have
    // been move to design include file, please use $INCLUDE_FILE to locate
    // user include file, by default sample_design.inc.cal will be included.
    // INCLUDE $TECHDIR/LVS/sample_design.inc.cal
    #IFDEF $TECHDIR
    #ENDIF
    VERBATIM {
    // Description Section                                               //
    //INCLUDE $TECHDIR/LVS/Include/cmos55lpe.extract.cal_ind
    //INCLUDE $TECHDIR/LVS/Include/cmos55lpe.layers.cal_ind
    INCLUDE $TECHDIR/LVS/Include/cmos55lpe.compare.cal
    LVS FILTER D(diodepwtw) OPEN
    LVS FILTER D(diodetwx) OPEN
    LVS FILTER D(diodenwx) OPEN
    LVS FILTER D(diodenx) OPEN
    LVS FILTER D(diodepnw) OPEN
    LVS FILTER D(diodedgnx) OPEN
    LVS FILTER D(diodedgpnw) OPEN
    LVS FILTER D(diodehvpwtw) OPEN
    LVS FILTER D(diodeisotwx) OPEN
    LVS SOFTCHK nband CONTACT
    LVS SOFTCHK psub CONTACT
    LVS SOFTCHK nw_no_n3 CONTACT
    LVS SOFTCHK nw_n3_t3 CONTACT
    #IFDEF ERC_RUN
       ERC SELECT CHECK FLOATING_CHKs
    #ENDIF
    ERC RESULTS DATABASE "./ERC_results.asc"
    ERC SUMMARY REPORT "./ERC_results.rep"
    // SET Series & Parallel STATEMENTS                                  //
    #IFNDEF REDUCE_SPLIT_GATES
       LVS REDUCE SPLIT GATES NO
    #ENDIF
    LVS REDUCE SEMI SERIES MOS             NO  //YES
    LVS REDUCE SERIES MOS                  NO  //YES
    LVS REDUCE PARALLEL BIPOLAR            YES //YES
    LVS REDUCE PARALLEL CAPACITORS         YES //YES
    LVS REDUCE PARALLEL DIODES             YES //YES
    LVS REDUCE PARALLEL MOS                YES //YES
    LVS REDUCE PARALLEL RESISTORS          YES //YES
    LVS REDUCE SERIES CAPACITORS           YES //YES
    LVS REDUCE SERIES RESISTORS            YES //YES
    LVS REDUCE D(tdpdnw) PARALLEL YES
    LVS REDUCE D(tdndsx) PARALLEL YES
    LVS REDUCE D(tddgpdnw) PARALLEL YES
    LVS REDUCE D(tddgndsx) PARALLEL YES
    // END SET REDUCE STATEMENTS                                         //
    // Set TRACE Tolerances - Do Not Change                              //
    VARIABLE trace_hg 2.5e-9
    VARIABLE trace_int 0.5
    VARIABLE trace_area 1e-15
    // End of Header Section                                             //
    // END OF FILE                                                       //
    But same error exist.
    Please help.
    Best regards,
    Marben
  • Quek
    Hi Marben
    I think there might be another "MASK SVDB DIRECTORY ..." cmd in the rule deck that has incorrect options and had overwritten your cmd. You can do a search in the rule deck directory:
    terminal> egrep -ir "mask svdb directory" /your-path/yourRuleDeckDir
    If you still cannot find the issue, it is best if you file a case to Mentor support so that they can first help to resolve the missing query files issue. I think it is most probably just a setup issue but it is difficult to debug without access to it.
    Best regards
    Quek
  • Marben
    Hi Quek,
    Here is the result of my egrep.
    I think they are all in comment.
    Best regards,
    Marben
  • Quek
    Hi Marben
    If you check Calibre LVS log file and report file, are you able to find any "MASK SVDB DIRECTORY" cmds?
    After adding cmd in Calibre LVS deck, did you remember to re-run LVS?
    Quek
  • Marben
    Hi Quek,
    I do not know what is the filename of my LVS log file,
    what is the extension name of calibre lvs log file?
    Yes, Aftre adding cmd in calibre lvs deck I rerun LVS then query.
    I can not find "MASK SVDB DIRECTORY" in my LVS report file.
    Fullscreen report_file.txt Download
                      ##         C A L I B R E    S Y S T E M         ##
                      ##             L V S   R E P O R T              ##
    REPORT FILE NAME:         pcd_inv_L.lvs.report
    LAYOUT NAME:              svdb/pcd_inv_L.sp ('pcd_inv_L')
    SOURCE NAME:              /home/marben/GF55/GF_stuff/Components/cmos10lpe_CDS_oa_dl064_15_20170731/DRC_LVS_Run_Area/pcd_inv_L.src.net ('pcd_inv_L')
    RULE FILE:                /home/marben/GF55/GF_stuff/Components/cmos10lpe_CDS_oa_dl064_15_20170731/DRC_LVS_Run_Area/_cmos55lpe.lvs_ref.cal_
    CREATION TIME:            Sun Mar 10 22:41:14 2019
    CURRENT DIRECTORY:        /home/marben/GF55/GF_stuff/Components/cmos10lpe_CDS_oa_dl064_15_20170731/DRC_LVS_Run_Area
    USER NAME:                marben
    CALIBRE VERSION:          v2017.1_34.33    Wed Apr 5 14:22:19 PDT 2017
                                   OVERALL COMPARISON RESULTS
                             #       ###################       _   _
                       #   #         #     CORRECT     #         |
                        # #          #                 #       \___/
                                          CELL  SUMMARY
      Result         Layout                        Source
      CORRECT        pcd_inv_L                     pcd_inv_L
                                          LVS PARAMETERS
    o LVS Setup:
       // LVS COMPONENT TYPE PROPERTY
       // LVS COMPONENT SUBTYPE PROPERTY
       // LVS PIN NAME PROPERTY
       LVS POWER NAME                         "VDD?" "DVDD?" "VDDC?" "VNWP?" "VDDP?" "VNW?" "VDD:P?" "VCC?" "VCC:P?" "WDPWRA?"
                                              "WDPWRB?" "WDPWR?"
       LVS GROUND NAME                        "VSS?" "GND?" "DVSS?" "SUB?" "sub"
       LVS CELL SUPPLY                        NO
       LVS RECOGNIZE GATES                    ALL
       LVS IGNORE PORTS                       NO
       LVS CHECK PORT NAMES                   NO
       LVS IGNORE TRIVIAL NAMED PORTS         NO
       LVS BUILTIN DEVICE PIN SWAP            NO
       LVS ALL CAPACITOR PINS SWAPPABLE       NO
       LVS DISCARD PINS BY DEVICE             NO
       LVS SOFT SUBSTRATE PINS                NO
       LVS INJECT LOGIC                       YES
       LVS EXPAND UNBALANCED CELLS            YES
       LVS FLATTEN INSIDE CELL                NO
       LVS EXPAND SEED PROMOTIONS             NO
       LVS PRESERVE PARAMETERIZED CELLS       NO
       LVS GLOBALS ARE PORTS                  YES
       LVS REVERSE WL                         NO
       LVS SPICE PREFER PINS                  NO
       LVS SPICE SLASH IS SPACE               YES
       LVS SPICE ALLOW FLOATING PINS          YES
       // LVS SPICE ALLOW INLINE PARAMETERS
       LVS SPICE ALLOW UNQUOTED STRINGS       NO
       LVS SPICE CONDITIONAL LDD              NO
       LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
       LVS SPICE IMPLIED MOS AREA             NO
       // LVS SPICE MULTIPLIER NAME
       LVS SPICE OVERRIDE GLOBALS             NO
       LVS SPICE REDEFINE PARAM               NO
       LVS SPICE REPLICATE DEVICES            YES
       LVS SPICE SCALE X PARAMETERS           NO
       LVS SPICE STRICT WL                    NO
       // LVS SPICE OPTION
       LVS STRICT SUBTYPES                    NO
       LVS EXACT SUBTYPES                     NO
       LAYOUT CASE                            NO
       SOURCE CASE                            NO
       LVS COMPARE CASE                       NO
       LVS DOWNCASE DEVICE                    NO
       LVS REPORT MAXIMUM                     50
       LVS PROPERTY RESOLUTION MAXIMUM        32
       // LVS SIGNATURE MAXIMUM
       // LVS FILTER UNUSED OPTION
       // LVS REPORT OPTION
       LVS REPORT UNITS                       YES
       // LVS NON USER NAME PORT
       // LVS NON USER NAME NET
       // LVS NON USER NAME INSTANCE
       // LVS IGNORE DEVICE PIN
       // Reduction
       LVS REDUCE SPLIT GATES                 YES [ TOLERANCE l 0 ]
       LVS REDUCE  MN(nfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MN(nfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  nfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  nfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MP(pfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MP(pfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(lvtnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(lvtnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  lvtnfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  lvtnfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(lvtpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(lvtpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(hvtnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(hvtnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  hvtnfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  hvtnfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(hvtpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(hvtpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgvnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgvnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  dgvnfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgvnfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgvpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgvpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  dgnfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgnfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgxnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgxnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  dgxnfettw  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgxnfettw  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgxpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgxpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natdgnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natdgnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natdgxnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MN(natdgxnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  ME(ednfet)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  ME(edpfet)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  M(isoednfet)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  M(isoedpfet)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  M(isosednfet)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  Q(ngrvpnp)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 mSwitch 0 ]
       LVS REDUCE  Q(vpnp)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 mSwitch 0 ]
       LVS REDUCE  Q(vnpn)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 ]
       LVS REDUCE  R(opppcres)  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  R(opppcres)  SERIES POS NEG [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  R(opppcres_1k)  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  R(opppcres_1k)  SERIES POS NEG [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  R(opndres)  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  R(opndres)  SERIES POS NEG [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  R(nwres)  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  R(nwres)  SERIES POS NEG [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  R(lvsres)  PARALLEL
       LVS REDUCE  R(rm1)  PARALLEL
       LVS REDUCE  R(rm2)  PARALLEL
       LVS REDUCE  R(rm3)  PARALLEL
       LVS REDUCE  R(rm4)  PARALLEL
       LVS REDUCE  R(rm5)  PARALLEL
       LVS REDUCE  R(rmea)  PARALLEL
       LVS REDUCE  subc  PARALLEL
       LVS REDUCE  subc  SERIES SUBCON sub NO
       LVS REDUCE  C(pcap)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(pcap)  SERIES POS NEG NO
       LVS REDUCE  C(dgpcap)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(dgpcap)  SERIES POS NEG NO
       LVS REDUCE  C(ncap)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(ncap)  SERIES POS NEG NO
       LVS REDUCE  C(dgncap)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(dgncap)  SERIES POS NEG NO
       LVS REDUCE  C(vncap)  PARALLEL NO
       LVS REDUCE  C(vncap)  SERIES POS NEG NO
       LVS REDUCE  C(apmom)  PARALLEL NO
       LVS REDUCE  C(apmom)  SERIES POS NEG NO
       LVS REDUCE  C(vncap_rf)  PARALLEL NO
       LVS REDUCE  C(vncap_rf)  SERIES POS NEG NO
       LVS REDUCE  C(apmom_rf)  PARALLEL NO
       LVS REDUCE  C(apmom_rf)  SERIES POS NEG NO
       LVS REDUCE  C(MOM20_rf)  PARALLEL NO
       LVS REDUCE  C(MOM24_rf)  PARALLEL NO
       LVS REDUCE  C(MOM25_rf)  PARALLEL NO
       LVS REDUCE  C(MOM20_rf)  SERIES POS NEG NO
       LVS REDUCE  C(MOM24_rf)  SERIES POS NEG NO
       LVS REDUCE  C(MOM25_rf)  SERIES POS NEG NO
       LVS REDUCE  sblkndres  PARALLEL NO
       LVS REDUCE  sblkpdres  PARALLEL NO
       LVS REDUCE  D(esdndsx)  PARALLEL
       LVS REDUCE  Q(esdvpnp)  PARALLEL [ TOLERANCE nf 0 A 0 ]
       LVS REDUCE  Q(esdvnpn)  PARALLEL [ TOLERANCE nf 0 A 0 ]
       LVS REDUCE  M(srpubpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpubpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpdbnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpdbnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgbnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgbnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpucpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpucpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpdcnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpdcnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgcnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgcnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpudpfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpudpfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpddnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpddnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgdnfet)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(srpgdnfet)  SERIES S D [ TOLERANCE l 0 ]
       LVS REDUCE  C(ncap_rf)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(ncap_rf)  SERIES POS NEG NO
       LVS REDUCE  C(dgncap_rf)  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  C(dgncap_rf)  SERIES POS NEG NO
       LVS REDUCE  pcap_rf  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  pcap_rf  SERIES G D NO
       LVS REDUCE  dgpcap_rf  PARALLEL [ TOLERANCE nf 0 w 0 l 0 nrep 0 composite 0 mSwitch 0 ]
       LVS REDUCE  dgpcap_rf  SERIES G D NO
       LVS REDUCE  MN(nfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  nfettw_rf  PARALLEL NO
       LVS REDUCE  MP(pfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(lvtnfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  lvtnfettw_rf  PARALLEL NO
       LVS REDUCE  M(lvtpfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  M(hvtnfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  hvtnfettw_rf  PARALLEL NO
       LVS REDUCE  M(hvtpfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgvnfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgvnfettw_rf  PARALLEL NO
       LVS REDUCE  MD(dgvpfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgxnfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgxnfettw_rf  PARALLEL NO
       LVS REDUCE  MD(dgxpfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  MD(dgnfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  dgnfettw_rf  PARALLEL NO
       LVS REDUCE  MD(dgpfet_rf)  PARALLEL [ TOLERANCE l 0 ]
       LVS REDUCE  ME(ednfet_rf)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  ME(edpfet_rf)  PARALLEL [ TOLERANCE l 0 w 0 ]
       LVS REDUCE  C(mimcap_alt)  PARALLEL [ TOLERANCE w 0 l 0 ]
       LVS REDUCE  C(mimcap_alt_bb)  PARALLEL [ TOLERANCE w 0 l 0 ]
       LVS REDUCE  C(mimcap_alt)  SERIES POS NEG NO
       LVS REDUCE  C(mimcap_alt_bb)  SERIES POS NEG NO
       LVS REDUCE  D(esdndsx_rf)  PARALLEL
       LVS REDUCE  Q(esdvpnp_rf)  PARALLEL [ TOLERANCE nf 0 A 0 ]
       LVS REDUCE  Q(esdvnpn_rf)  PARALLEL [ TOLERANCE nf 0 A 0 ]
       LVS REDUCE  R(oprppres)  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  R(oprppres)  SERIES POS NEG [ TOLERANCE w 0 l 0 s 0 pbar 0 ]
       LVS REDUCE  npolyf_s  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  npolyf_u  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  ppolyf_s  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  nplus_s  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  pplus_s  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  pplus_u  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  nwella  PARALLEL [ TOLERANCE w 0 l 0 s 0 ]
       LVS REDUCE  npolyf_s  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  npolyf_u  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  ppolyf_s  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  nplus_s  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  pplus_s  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  pplus_u  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  nwella  SERIES PLUS MINUS [ TOLERANCE w 0 l 0 pbar 0 ]
       LVS REDUCE  MN(nmos_5p0_asym)  PARALLEL [ TOLERANCE l 0 w 0 nf 0 ]
       LVS REDUCE  MP(pmos_5p0_asym)  PARALLEL [ TOLERANCE l 0 w 0 nf 0 ]
       LVS REDUCTION PRIORITY                 PARALLEL
       LVS SHORT EQUIVALENT NODES             NO
       // Filter
       // Trace Property
       TRACE PROPERTY  mn(nfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(nfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  lvtnfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  lvtnfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  hvtnfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  hvtnfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgvnfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgvnfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgnfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgnfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgxnfettw  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgxnfettw  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natdgnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natdgnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natdgxnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(natdgxnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(ednfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(ednfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(edpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(edpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isoednfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isoednfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isoedpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isoedpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isosednfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(isosednfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(ngrvpnp)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(ngrvpnp)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(ngrvpnp)  nf nf 0
       TRACE PROPERTY  q(ngrvpnp)  nrep nrep 0
       TRACE PROPERTY  q(ngrvpnp)  m m 0
       TRACE PROPERTY  q(vpnp)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(vpnp)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(vpnp)  nf nf 0
       TRACE PROPERTY  q(vpnp)  nrep nrep 0
       TRACE PROPERTY  q(vpnp)  m m 0
       TRACE PROPERTY  q(vnpn)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(vnpn)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  q(vnpn)  nf nf 0
       TRACE PROPERTY  q(vnpn)  nrep nrep 0
       TRACE PROPERTY  q(vnpn)  m m 0
       TRACE PROPERTY  r(opppcres)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres)  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres)  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres_1k)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres_1k)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres_1k)  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opppcres_1k)  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opndres)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opndres)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opndres)  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(opndres)  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(nwres)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(nwres)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(nwres)  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(nwres)  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm1)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm1)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm2)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm2)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm3)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm3)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm4)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm4)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm5)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rm5)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rmea)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(rmea)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(pcap)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(pcap)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(pcap)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(pcap)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(pcap)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgpcap)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgpcap)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgpcap)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgpcap)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgpcap)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  c(ncap)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(ncap)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(ncap)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(ncap)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(ncap)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgncap)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgncap)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  c(vncap)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(vncap)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(vncap)  botlev botlev 0.5
       TRACE PROPERTY  c(vncap)  toplev toplev 0.5
       TRACE PROPERTY  c(apmom)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(apmom)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(apmom)  botlev botlev 0.5
       TRACE PROPERTY  c(apmom)  toplev toplev 0.5
       TRACE PROPERTY  c(vncap_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(vncap_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(vncap_rf)  botlev botlev 0.5
       TRACE PROPERTY  c(vncap_rf)  toplev toplev 0.5
       TRACE PROPERTY  c(apmom_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(apmom_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(apmom_rf)  botlev botlev 0.5
       TRACE PROPERTY  c(apmom_rf)  toplev toplev 0.5
       TRACE PROPERTY  c(mom20_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom20_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom20_rf)  botlev botlev 0.5
       TRACE PROPERTY  c(mom20_rf)  toplev toplev 0.5
       TRACE PROPERTY  c(mom20_rf)  shield_option shield_option 0
       TRACE PROPERTY  c(mom24_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom24_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom24_rf)  botlev botlev 0.5
       TRACE PROPERTY  c(mom24_rf)  toplev toplev 0.5
       TRACE PROPERTY  c(mom24_rf)  shield_option shield_option 0
       TRACE PROPERTY  c(mom25_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom25_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mom25_rf)  botlev botlev 0.5
       TRACE PROPERTY  c(mom25_rf)  toplev toplev 0.5
       TRACE PROPERTY  c(mom25_rf)  shield_option shield_option 0
       TRACE PROPERTY  sblkndres  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  sblkndres  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  sblkpdres  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  sblkpdres  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  d(esdndsx)  a a 1
       TRACE PROPERTY  d(esdndsx)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  d(esdndsx)  perim perim 1
       TRACE PROPERTY  q(esdvpnp)  a a 1
       TRACE PROPERTY  q(esdvpnp)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  q(esdvnpn)  a a 1
       TRACE PROPERTY  q(esdvnpn)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  esdscr_dw  nf nf 0
       TRACE PROPERTY  esdscr_dw  ntds ntds 0
       TRACE PROPERTY  esdscr_dw  areapd areapd 1
       TRACE PROPERTY  esdscr_dw  perimpd perimpd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_dw  areanw areanw 1
       TRACE PROPERTY  esdscr_dw  perimnw perimnw 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_dw  areand areand 1
       TRACE PROPERTY  esdscr_dw  perimnd perimnd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw  nf nf 0
       TRACE PROPERTY  esdscr_tw  ntds ntds 0
       TRACE PROPERTY  esdscr_tw  areapd areapd 1
       TRACE PROPERTY  esdscr_tw  perimpd perimpd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw  areanw areanw 1
       TRACE PROPERTY  esdscr_tw  perimnw perimnw 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw  areand areand 1
       TRACE PROPERTY  esdscr_tw  perimnd perimnd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw  areapw areapw 1
       TRACE PROPERTY  esdscr_tw  perimpw perimpw 1e-07 ABSOLUTE
       TRACE PROPERTY  m(srpubpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpubpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpdbnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpdbnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgbnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgbnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpucpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpucpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpdcnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpdcnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgcnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgcnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpudpfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpudpfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpddnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpddnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgdnfet)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(srpgdnfet)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  symindp  din din 0
       TRACE PROPERTY  symindp  width width 0
       TRACE PROPERTY  symindp  n n 0
       TRACE PROPERTY  symindp  ct ct 0
       TRACE PROPERTY  symindp  shield shield 0
       TRACE PROPERTY  c(ncap_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(ncap_rf)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(ncap_rf)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(ncap_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(ncap_rf)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgncap_rf)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap_rf)  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(dgncap_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(dgncap_rf)  m m 0.5 ABSOLUTE
       TRACE PROPERTY  pcap_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pcap_rf  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  pcap_rf  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  pcap_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pcap_rf  m m 0.5 ABSOLUTE
       TRACE PROPERTY  dgpcap_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgpcap_rf  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  dgpcap_rf  nrep nrep 0.5 ABSOLUTE
       TRACE PROPERTY  dgpcap_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgpcap_rf  m m 0.5 ABSOLUTE
       TRACE PROPERTY  mn(nfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(nfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtnfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtnfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  lvtnfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  lvtnfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(lvtpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtnfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtnfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  hvtnfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  hvtnfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  m(hvtpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvnfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvnfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgvnfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgvnfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgvpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxnfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxnfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgxnfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgxnfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgxpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgnfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgnfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgnfettw_rf  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  dgnfettw_rf  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  md(dgpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(ednfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(ednfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(edpfet_rf)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  me(edpfet_rf)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt)  lrep lrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt)  wrep wrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt_bb)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt_bb)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt_bb)  lrep lrep 0.5 ABSOLUTE
       TRACE PROPERTY  c(mimcap_alt_bb)  wrep wrep 0.5 ABSOLUTE
       TRACE PROPERTY  indp  n n 0
       TRACE PROPERTY  indp  din din 0
       TRACE PROPERTY  indp  width width 0
       TRACE PROPERTY  indp  shield shield 0
       TRACE PROPERTY  d(esdndsx_rf)  a a 1
       TRACE PROPERTY  d(esdndsx_rf)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  d(esdndsx_rf)  perim perim 1
       TRACE PROPERTY  q(esdvpnp_rf)  a a 1
       TRACE PROPERTY  q(esdvpnp_rf)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  q(esdvnpn_rf)  a a 1
       TRACE PROPERTY  q(esdvnpn_rf)  nf nf 0.5 ABSOLUTE
       TRACE PROPERTY  r(oprppres)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(oprppres)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(oprppres)  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  r(oprppres)  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  bondpad  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  bondpad  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  bondpad  bp bp 0
       TRACE PROPERTY  bondpad  rect rect 0
       TRACE PROPERTY  esdscr_dw_rf  nf nf 0
       TRACE PROPERTY  esdscr_dw_rf  ntds ntds 0
       TRACE PROPERTY  esdscr_dw_rf  areapd areapd 1
       TRACE PROPERTY  esdscr_dw_rf  perimpd perimpd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_dw_rf  areanw areanw 1
       TRACE PROPERTY  esdscr_dw_rf  perimnw perimnw 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_dw_rf  areand areand 1
       TRACE PROPERTY  esdscr_dw_rf  perimnd perimnd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw_rf  nf nf 0
       TRACE PROPERTY  esdscr_tw_rf  ntds ntds 0
       TRACE PROPERTY  esdscr_tw_rf  areapd areapd 1
       TRACE PROPERTY  esdscr_tw_rf  perimpd perimpd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw_rf  areanw areanw 1
       TRACE PROPERTY  esdscr_tw_rf  perimnw perimnw 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw_rf  areand areand 1
       TRACE PROPERTY  esdscr_tw_rf  perimnd perimnd 1e-07 ABSOLUTE
       TRACE PROPERTY  esdscr_tw_rf  areapw areapw 1
       TRACE PROPERTY  esdscr_tw_rf  perimpw perimpw 1e-07 ABSOLUTE
       TRACE PROPERTY  mn(nmos_5p0_asym)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mn(nmos_5p0_asym)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pmos_5p0_asym)  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  mp(pmos_5p0_asym)  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_s  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_s  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_s  m m 0
       TRACE PROPERTY  npolyf_s  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_s  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_u  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_u  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_u  m m 0
       TRACE PROPERTY  npolyf_u  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  npolyf_u  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  ppolyf_s  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  ppolyf_s  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  ppolyf_s  m m 0
       TRACE PROPERTY  ppolyf_s  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  ppolyf_s  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nplus_s  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nplus_s  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nplus_s  m m 0
       TRACE PROPERTY  nplus_s  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nplus_s  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_s  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_s  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_s  m m 0
       TRACE PROPERTY  pplus_s  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_s  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_u  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_u  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_u  m m 0
       TRACE PROPERTY  pplus_u  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  pplus_u  pbar pbar 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nwella  l l 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nwella  w w 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nwella  m m 0
       TRACE PROPERTY  nwella  s s 2.5e-09 ABSOLUTE
       TRACE PROPERTY  nwella  pbar pbar 2.5e-09 ABSOLUTE
                       CELL COMPARISON RESULTS ( TOP LEVEL )
                       #   #         #     CORRECT     #         |
                        # #          #                 #       \___/
    LAYOUT CELL NAME:         pcd_inv_L
    SOURCE CELL NAME:         pcd_inv_L
    NUMBERS OF OBJECTS
                    Layout    Source         Component Type
     Ports:              5         5
     Nets:               5         5
     Instances:          2         2         MD (4 pins)
     Total Inst:         2         2
                                   INFORMATION AND WARNINGS
                      Matched    Matched    Unmatched    Unmatched    Component
                       Layout     Source       Layout       Source    Type
       Ports:               5          5            0            0
       Nets:                5          5            0            0
       Instances:           1          1            0            0    MD(DGNFET)
                            1          1            0            0    MD(DGPFET)
       Total Inst:          2          2            0            0
    o Layout Names That Are Missing In The Source:
       Ports:        VN:
       Nets:         VN:
    o Initial Correspondence Points:
       Ports:        SB VP A Y
                                             SUMMARY
    Total CPU Time:      1 sec
    Total Elapsed Time:  1 sec
    Best regards,
    Marben
  • Quek
    Hi Marben
    I think it would be best if you contact Mentor support centre to sort out the Calibre LVS and query issues first.
    Best regards
    Quek
  • Marben
    Hi Quek,
    Yes, I will contact Mentor support.
    Thank you very much for your help.
    Best regards,
    Marben
