  3. Schematic check and save error
  • Views 21195
HarshP707
HarshP707 over 7 years ago
I am a newbie to this forum so excuse me for mt first question.
I am getting some strange error without any explanation while performing "check and save" for my schematic on virtuoso.
Error reads:
*Error* round: argument #1 should be a number (type template = "n") - nil
Version: ICADV12.3-64b.500.21
Can someone share the reason for this and possible fix to try out?
Thank you!
Harsh
    Hi Harsh,
    Please enter these in the CIW:
    _stacktrace=50
    tracelength=tracelevel=50
    sstatus(errsetTrace t)
    Then do the check-and-save. Please then post any stack trace info you get in the CIW.
  • HarshP707
    HarshP707 over 7 years ago in reply to Andrew Beckett
    The log that is generated after running your commands has my employer's information that I am not sure if I can share publicly.
    Any other way to share it?
    Harsh
  • HarshP707
    HarshP707 over 7 years ago in reply to HarshP707
    Andrew,
    It is solved.
    Thank you for your help!
    It was due to missing one of the parameters for the device.
    H
    Andrew Beckett over 7 years ago in reply to HarshP707
    Harsh,
    My guess is that the trace info only gave company information because there was some company-specific customisation doing a custom check. Check and Save doesn't normally check parameters on the devices, so I can only assume there is an error in this custom check and it does not gracefully produce an error when a parameter is missing. You might want to get somebody in your company to fix that custom check (assuming my guess about this being a custom check is true).
  • HarshP707
    Thank you, Andrew!
