  3. Stochastic-mismatch model in Verilog-A
  • Views 15785
Esteban22
Esteban22 over 7 years ago
Hello cadence community,
I have a question about adding models when trying to set up an MC simulation. I will be clear enough in what i'm doing:
1| I have my Verilog-A model working with no problems in DC and transient simulations. I've understood that I can use the following line of code in Verilog-A to declare a parameter and then call it in an input file:
(*cds_inherited_parameter*)parameter real my_parameter = 0;
2| When I set up my simulation (by using ADE-L or ADE-XL) in "Model Libraries Setup" I add a model file "myfile.scs" where "my_parameter" declared in my Verilog-A model is called:
simulator lang=spectre
parameters my_parameter=0.5
statistics {
            mismatch{
                     vary my_parameter dist=unif N=0.5
3| Now, I've understood that "myfile.scs" notation is used for spectre. But I'm trying to use hspice so, I want to create a new file "myfile.sp" and add it to in "Model Libraries Setup" when doing a simulation. I want to call "my_parameter" (and do a process mismatch) which is in my verilog-A model but this time using hspice. How can I do it?
Best Regards,
Esteban
    Andrew Beckett over 7 years ago +1
    Esteban, This forum is probably not the best place to ask a question about HSPICE, which is a Synopsys tool (not a Cadence tool). You'd be better off asking it in a Synopsys forum or for Synopsys customer…
    Esteban,
    This forum is probably not the best place to ask a question about HSPICE, which is a Synopsys tool (not a Cadence tool). You'd be better off asking it in a Synopsys forum or for Synopsys customer support.
  • Esteban22
    Esteban22 over 7 years ago in reply to Andrew Beckett
    Andrew,
    Thank you for your fast response. I clearly misunderstood the tool concepts.
    Esteban
