  3. ERROR [SFE-874]:'Unexpected end of line' while running a...
  • Replies 18
  • Subscribers 132
  • Views 44095
ERROR [SFE-874]:'Unexpected end of line' while running a .scs file generated using ADE L, cadence Virtuoso v6.1.4 with spectre
Chandu D
Chandu D over 7 years ago
I am trying to simulate a basic inverter circuit using spectre. I have generated a netlist file. when I run it, I am getting the following error
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 2: Unexpected end of line. Expected equals sign, numeric value or string value.
For your referrence, I am posting the files 'cds.lib', 'input.scs' and 'spectre.out' here. Can someone help me out. Thanks in advance
*************cds.lib********************
#Following defined by Chandrasekhar DVS
DEFINE analogLib /usr/local/IC614/tools/dfII/etc/cdslib/artist/analogLib
DEFINE US_8ths /usr/local/IC614/tools/dfII/etc/cdslib/sheets/US_8ths
DEFINE basic /usr/local/IC614/tools/dfII/etc/cdslib/basic
DEFINE cdsDefTechLib /usr/local/IC614/tools/dfII/etc/cdsDefTechLib
DEFINE NCSU_TechLib_FreePDK15 $PDK_DIR/cdslib/NCSU_TechLib_FreePDK15
DEFINE ADETutorial /home/eslam/ADETutorial_1/ADETutorial
DEFINE SPECTRE_TUTORIAL /home/eslam/ADETutorial_1/SPECTRE_TUTORIAL
#DEFINE analogLib $CDS/IC/tools/dfII/etc/cdslib/artist/analogLib
#DEFINE US_8ths $CDS/IC/tools/dfII/etc/cdslib/sheets/US_8ths
#DEFINE basic $CDS/IC/tools/dfII/etc/cdslib/basic
#DEFINE cdsDefTechLib $CDS/IC/tools/dfII/etc/cdsDefTechLib
************* input.scs****************
// Generated for: spectre
// Generated on: Apr 21 11:31:37 2019
// Design library name: SPECTRE_TUTORIAL
// Design cell name: myInverterTB
simulator lang=spectre
global 0 vdd!
parameters VDD_VAL=0.8
include "/home/eslam/ADETutorial_1/cds.lib"
// Library name: SPECTRE_TUTORIAL
// Cell name: myInverter
// View name: schematic
subckt myInverter I O inh_bulk_n inh_bulk_p
I2 (O I inh_bulk_p inh_bulk_p) pmos
I6 (O I inh_bulk_n inh_bulk_n) nmos
ends myInverter
// End of subcircuit definition.
// Cell name: myInverterTB
I5 (IN OUT 0 vdd!) myInverter
V0 (vdd! 0) vsource dc=VDD_VAL type=dc
V1 (IN 0) vsource type=pulse val0=0 val1=VDD_VAL period=20p delay=0 \
rise=1p fall=1p width=9p
C0 (OUT 0) capacitor c=1f
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
checklimitdest=psf
tran tran stop=40p write="spectre.ic" writefinal="spectre.fc" \
annotate=status maxiters=5
save IN OUT
***************spectre.out************
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.1.1.187.isr11 32bit -- 18 Aug 2009
Copyright (C) 1989-2009 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
7,085,700; 7,143,021; 7,493,240.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: root Host: localhost.localdomain HostID: 7F0100 PID: 5290
Memory available: 1.0215 GB physical: 1.9854 GB
CPU(1 of 2): CPU 0 Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz 2200.000MHz
Simulating `input.scs' on localhost.localdomain at 11:40:05 AM, Sun Apr 21, 2019 (process id: 5290).
Environment variable:
SPECTRE_DEFAULTS=-E
Command line:
/usr/local/IC614/MMSIM/tools.lnx86/spectre/bin/32bit/spectre \
input.scs +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_3079_6 -format sst2 -raw ../psf +lqtimeout \
900 -maxw 5 -maxn 5
spectre pid = 5290
Loading /usr/local/IC614/MMSIM/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /usr/local/IC614/MMSIM/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /usr/local/IC614/MMSIM/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /usr/local/IC614/MMSIM/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Error found by spectre during circuit read-in.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 3: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 4: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 5: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 6: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 7: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 8: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 9: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 10: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 11: Unexpected end of line. Expected equals sign, numeric value or string value.
ERROR (SFE-874): "/home/eslam/ADETutorial_1/cds.lib" 13: Unexpected end of file. Expected equals sign, numeric value or string value.
Time for parsing: CPU = 195.97 ms, elapsed = 347.244 ms.
Time accumulated: CPU = 243.962 ms, elapsed = 348.989 ms.
Peak virtual memory used = 552 Mbytes.
Aggregate audit (11:40:06 AM, Sun Apr 21, 2019):
Time used: CPU = 245 ms, elapsed = 350 ms, util. = 69.9%.
Time spent in licensing: elapsed = 177 ms, percentage of total = 50.5%.
Virtual memory used = 552 Mbytes.
spectre completes with 11 errors, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
    Andrew Beckett over 7 years ago in reply to Chandu D
    Sending a screenshot of the netlist isn't terribly helpful - I'm not going to type it in again to test it!
    That said, it's not dissimilar to what I'd tried before except I used a supply voltage of 1.2V rather than 2V. If I change to 2V I get the blowup you do - I suspect the models are not terribly tolerant of such high voltages (2V would be quite high for a FinFET device).
    I think this is a consequence of the models (which are probably very basic). Can you use a lower supply voltage? You should probably take this up with NCSU.
  • Chandu D
    Chandu D over 7 years ago in reply to Andrew Beckett
    ohk sorry. Here is the input.scs
    // Generated on: Apr 28 01:14:04 2019
    // Design library name: inv_tut
    global 0 vdd!
    include "/root/Desktop/Manusai/Tech_Lib/NCSU-FreePDK15/FreePDK15/hspice/models/fet.inc" section=CMG
    // Library name: inv_tut
    M0 (_net0 _net1 0 0) nmos w=100n l=15n as=6.08e-16 ad=6.08e-16 ps=168n \
    pd=168n m=2 degradation=no
    M1 (_net0 _net1 vdd! vdd!) pmos w=100n l=15n as=6.08e-16 ad=6.08e-16 \
    ps=168n pd=168n m=2 degradation=no
    V0 (vdd! 0) vsource dc=2 type=dc
    V1 (_net1 0) vsource type=pulse val0=0 val1=2 period=20p delay=0 rise=1p \
    fall=1p width=9p
    checklimitdest=psf
    We tried with smaller voltages of vdc (1.2V and 800mV) but are still getting blowup. can you tell me what did you set your values for vpulse?
    I'm guessing that you set the DC supply to 1.2V but left the pulse source at 2V. That's not a good idea... you don't want your pulse source exceeding the supply voltage. Set the high voltage of the pulse to match your DC supply (in ADE probably a good idea to create a design variable and set both sources to use the same variable.
    If you have a supply of 1.2V and a pulse peak of 2V, the blowup occurs during the transient when the pulse source goes high.
    Blowups are fairly rare in spectre and is usually an indication of poorly characterised models (I suspect they have non-physical behaviour outside a certain voltage range).
  • Chandu D
    Thanks Andrew! we finally were able to simulate the inverter circuit. The only thing bothering me is the following (1st picture from my above reply which is third last excluding this one)
    Notice from spectre during circuit read-in.
    "/root/Desktop/Manusai/Tech_Lib/NCSU-FreePDK15/FreePDK15/hspice/models/fet.inc" 41: Version message is not given, map to bsimmg.
    "/root/Desktop/Manusai/Tech_Lib/NCSU-FreePDK15/FreePDK15/hspice/models/fet.inc" 70: Version message is not given, map to bsimmg.
    would simulating the circuit still mean we are working with FinFET or other variants of MGFETs?
    It's a typo in the warning message. It should be telling you that it mapped to bsimcmg (not bsimmg) which is the model used for FinFET. I was going to ask R&D to fix it, but I think it's a waste of their time given that this would only occur in old hspice models that don't have the version specified - which is likely to be a rare occurrence these days (except in these academic models).
    If you look in the circuit inventory portion of the spectre log, it will say you have bsimcmg devices.
  • Chandu D
    Thanks Andrew. One last question...can you tell me where is the spectre log file generally located? I tried searching in some log files just now but in vain...
    If running from ADE L (which I assume you are), then using Simulation->Output Log will display it. If  you enlarge the window, you'll see the full path to the file in the banner of the window - which shows you that it's in the psf directory parallel to the netlist directory that contains the input.scs
  • Chandu D
    Thank you very much Andrew!!
