  3. Maestro: Could not find state ..../spectre/active activ...
  • Replies 9
  • Views 7845
Maestro: Could not find state ..../spectre/active active
HoWei
HoWei over 7 years ago
We do have 2 similar maestro views "maestro_lpe" and "maestro_sch". Both view do contain variables and outputs in the users workarea.
The user checked in the files in our revision control system SOS.
When checking out the cell by other users, the "maestro_sch" is not working. No variables and outputs are visible for other users after checkout of this cell. In the CIW the following message comes:
WARNING (ADE-1077): Could not find state /icd/sim/hflroic_g6r3/uidn5147/sos_main/sim/G6R3_tb/mm_test_sig_and_xt/maestro_sch/G6R3_tb/mm_test_sig_and_xt/spectre/active active.
WARNING (EXPLORER-1648): The 'G6R3_tb/mm_test_sig_and_xt/maestro_sch' cellview has been opened in the read-only mode.
       The setting for the number of history entries to be saved, specified using the
       Save Options form or the adexl.simulation saveLastNHistoryEntries environment
       variable, will be applied only to the histories created in this session.
       Histories saved in the previous sessions will not be removed.
When comparing the content of the view-folders of "maestro_sch" and "maestro_lpe" I see that a file "active.state" is only existing in "maestro_lpe". That is also true for the users folders - not only for the checked-out folders. But the user does see all outputs and variables.
What can be the problem here  - any idea ?
IC6.1.8.010 on RHEL6 and RHEL7
  • HoWei
    Apparently the file "active.state" is created when the "maestro_sch" is checked out and opened-for-edit. But the message in CIW still appears and the variables and outputs are not shown.
    It seems like the file "maestro.sdb" contains all these variables and outputs in the users workarea.
    But in the checked-out workarea this file does not contain the variables and outputs.
    There seems to be an issue with our revision control system, that it does not send the correct file content to the repository.
    Andrew Beckett over 7 years ago in reply to HoWei
    This suggests that something has got lost (maybe in your Design Management system). The active.state contains all the test setup, whereas the maestro.sdb contains the overall view of all the tests including global variables.
    Perhaps your design management tool is not honouring the "co-managed set" (either because it's not properly using GDM or has an outdated replica of the same co-managed information).
  • HoWei
    HoWei over 7 years ago in reply to Andrew Beckett
    Can you explain what you mean with "co-managed-set" ?
    If you run:
    UNIX> `cds_root virtuoso`/bin/dregprint -dataFormat Maestro
    DataFormat Maestro {
    Pattern = maestro.sdb;
      Default_Editor = Maestro-Editor;
      updaterProg = ccpAdexlUpdtr;
      Co_Managed = data.dm results/*/*.rdb results/*/*.log results/*/*.db *.state xmlstate maestro.sdb master.tag ScriptDir/* ScriptDir/.record ScriptDir/.recordDetail states/*     states/*/test_states/*/*/*/*/* states/*/test_states/*/*/*/*/.record states/*/test_states/*/*/*/*/.recordDetail states/*.sdb states/*/*.state states/*/ScriptDir/* states/*/ScriptDir/.record states/*/ScriptDir/.recordDetail documents/* documents/*/* documents/*/*/* documents/*/*/*/* documents/*/*/*/*/* documents/*/*/*/*/*/* documents/*/*/*/*/*/*/* datasheets/*.* states/*/test_states/*/*/*/*/.sevSaveDir waveformSetup/*/* test_states/*.state test_states/*.ScriptDir/* test_states/*.ScriptDir/.record test_states/*.ScriptDir/.recordDetail *.TCL;
    dfII_ViewType = maestro;
      Initial_File = maestro.sdb;
    This tells you the pattern for the files that should be managed together. So that means that when you check in a cellView, all of the files must be managed together as they are interrelated. It's rather complicated because of legacy support for some unconverted files from ADE XL so in practice most of those files don't exist (the above is from IC618 by the way).
  • HoWei
    Our revision-control-system (Cliosoft SOS) does apply co-managed-sets to the cellviews - I checked that. The cellview is managed as one entity. I does not operate on separate file inside the cellview. The folder "maestro_sch" has only 3 files (data.dm, maestro.sdb, master.tag).
    The above comment, that the "maestro.sdb" is an empty file is not true anymore - after changing revision back and forth it was showing the correct content. May I did not properly update before - but the revision control system can be ruled out from the culprits.
    But problem remains.
    Then I copied the files from the users workarea directly to my workarea.
    Tried with IC6.1.7
    Any idea what the above WARNING (ADE-1077) means ?
    The file it is looking for does not exist in the user workarea at all.
  • HoWei
    By looking closer to the search-path of the missing file I observed 2 things I had overseen before:
    - the search-path is messed-up, it contains 2 times the folder "G6R3_tb/mm_test_sig_and_xt/"
    - it is looking in the simulation folder (not in the lib-path as assumed before)
    But the file/folder does not even exist in the users simulation folder.
    Why does ADE want to find this folder ?
  • HoWei
    HoWei over 7 years ago in reply to HoWei
    I also found that in the users workarea (where "maestro_sch") is working, in the simulation folder the file "active.state" is existing - thatswhy it is working in his  workarea and not in the other users workarea.
    I only get the "maestro_sch" in my workarea working when I copy the "active.state" into my simulation folder - copying to the library cell-folder does not help.
    Why ?
    To conclude the findings:
    1. The user created a "maestro_sch" cell-view
    2. Somehow the file "active.state" is not located in the library, but it is located in the simulation folder
    3. The user checked in the "maestro_sch" cell-view to our SO repository
    4. The other users are populating his cell-view in their library, but are missing the "active.state" and getting the error.
    I am wondering how this dependence on the simulation folder was created ?
    Is this a new feature or bug of IC6.1.8 that can happen ?
    This sounds very odd. I've not seen it myself before and my theories about it (opening a new maestro view, not saving any tests, then closing and reopening in readonly) didn't reproduce it.
    However, since I see you've now logged case 46358334 I'll leave it to my colleague in the support team to handle this - it does seem strange.
  • HoWei
    According to Cadence support this is a bug which was fixed in IC6.1.7 ISR22 onwards.
    It is caused by copying a maestro-view via "save a copy", when the maestro-view is openend "read-only". Then the file "active.state" is not copied. If then the maestro-view is opened by another user, the required "active.state" is searched in the simulation folder - where it does  not exist for this other user of course.
    It seems that in our case, the maestro-view was created in ic6.1.7.500.1400 and not in ic6.1.8.010 as we assumed before.
    I verfified that when creating the "save a copy" in 6.1.8.010 this problem does not exist anymore.
