  3. Cannot extract spectre transient simulation data using ...
  • Replies 7
  • Subscribers 136
  • Views 18830
Cannot extract spectre transient simulation data using Matlab
peter6g
peter6g over 7 years ago
I am using a Matlab code to extract Spectre transient simulation data for diode devices.  It worked when my tool versions are as follows:
mmsim 11.1.ISR20
matlab 7.11
redhat 6
But when I switched over to the following tool versions, my Matlab code no longer works:
mmsim 16.1.ISR9
matlab 8.3
readhat 6
The funny thing is, using the same Matlab code in the latter tool versions I have no problem extracting DC operating data for diode devices.  It also works for both MOSFET DC an transient device data.
Do I just need to change Matlab to another version (if so, which ones?)?  Or was there some sort of change in the diode device transient data format between mmsim 11 and mmsim 16 that my Matlab code need to adapt to?
    "Doesn't work" isn't very specific. However, you are using a 5 year old version of Matlab with a 3 year old version of Spectre.
    There is coverage of what was tested at the time Matlab-SpectreRF support matrix MMSIM 7.2, 10.1, 11.1 which suggests that MATLAB 8.3 (2014a) should work with SPECTRE16.1 (in 64 bit mode).
    So what exactly doesn't work? I may be able to test this when back in my office next week (I'm travelling this week and so don't have access to every version I normally would).
  • peter6g
    peter6g over 7 years ago in reply to Andrew Beckett
    The matlab program isn't able to find the diode current value.  I suspected that the terminal names of the diodes have changed, so I've modified terminal names to match those seen in the Results Browser, but that didn't work.
  • peter6g
    Problem solved. I had to change the save format to psfxl and save all currents.  According o mmsim 16.1 "What's New" there was a change in the save options.
    Andrew Beckett over 7 years ago in reply to peter6g
    Ah, good timing - I was literally just starting to look at this!
  • peter6g
    Hi Andrew.  Is there any documentation I can look at to see which Matlab versions are compatible with mmsim 16.1?  From an older post you mentioned that the "Matlab Support Matrix" section in Spectre simulator manual isn't updated anymore, which is definitely true in the 16.1 manual.  I am also interested in knowing the matrix for mmsim 17, 18, and 19.
    Try this link: MMSIM Spectre, APS, SpectreRF and Matlab support matrix
  • peter6g
    Eureka!  Thank you!
