  3. Changing default editor within ADE
  • Views 15910
BrJaWr
BrJaWr over 7 years ago
I'd like to be able to use "vim" as my default editor and viewer in ADE.  For example, when I view a netlist from a corner.  In the past I think I could just set
viewer = "/path/vim"
editor="/path/vim"
in my cdsinit. but this does't seem to work.
  Is there a different way?
    No, this never worked. The netlist viewer in ADE is always using the view() function.
  • BrJaWr
    BrJaWr over 7 years ago in reply to Andrew Beckett
    Is there an easy way to change both the editor and viewer?  Do we have to replace the view function?
    Andrew Beckett over 7 years ago in reply to BrJaWr
    Well, there isn't a netlist editor anyway. The "editor" variable does alter things that use the edit() function.
    There is no way to replace the built-in viewer unless the applications support it directly. For example, some things (such as the spectre output log) are annotated with hypertext links which wouldn't work if you'd replaced it with an external editor.
