  3. Differential STB analysis in Explorer
  • Views 15934
Victor Koren
Victor Koren over 7 years ago
In explorer I dont find the option of using differential STB probes. I had the option in ADE L.
    You need to probe an instance of diffstbprobe in your schematic - then you'll get the option on the form to pick the common-mode or differential-mode stability. The behaviour is the same between ADE L and ADE Explorer - you had to probe a diffstbprobe in ADE L too.
  • Victor Koren
    Victor Koren over 7 years ago in reply to Andrew Beckett
    Thanks Andrew.
    My memory not as good as it was once...
    Victor
