  3. ADE L psf dcOpIno MOS data is scalar but XL psf is wave
  • Views 2698
FormerMember
FormerMember over 7 years ago
When using oppoints from ADE L psf the data is scalar but the same as a Test in XL gives data that is wave at design point 0 even if no sweep specified.. You have to use the data at value(0). Also functions like report(?type "bsim4" ?param "vth") wont work on this XL psf. Not tried Explorer yet
IC6.1.7-64b.500.21
    How are you opening the data to do further processing on it? What further processing are you doing? If you use the report() function, you could use openResults() on the individual point directory psf results rather than the top level (which is across all the runs, even if only one).
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    Thanks Andrew, I am opening the results browser from the history tab and passing the psf path as a command line argument to my script where i do an openResults on this top level. Eventually I want to print out a chosen MOS oppoint across all corners/sweeps (without knowing what the corner/sweep names are) and checking if above or below a limit. I am starting with no corners/sweeps thus;
    foreach(mosDev mosDevs
     mosId=abs(value(pv(mosDev "id") 0  ))
     if(mosId>1p
      fprintf(fd,"Device:%s,current:%f uA\n" mosDev,mosId/1u)
    I see other people have been asking similar things;
    https://community-prod.cadence.com/cadence_technology_forums/f/custom-ic-design/36760/skill-print-voltage-to-a-text-file-in-ade-xl-over-corners
  • FormerMember
    FormerMember over 7 years ago in reply to FormerMember
    Hi Andrew i have just seen your post on sweepValues() and sweepNames() etc ;
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/40716/filtering-data-to-plot-for-nested-sweeps
    so perhaps I have to foreach across all these
  • FormerMember
    Hi Andrew or someone, based on the above links i wrote the code to access MOS oppoints at all corners and sweeps;
    selectResults('dcOpInfo)
    ;dataTypes()
    mosDevs=outputs(?type "bsim4")
    sweepNames0=nth(0 sweepNames())
    sweepNames1=nth(1 sweepNames())
    sweepNames2=nth(2 sweepNames())
    sweepNames3=nth(3 sweepNames())
    sweepVarValues0=sweepVarValues(sweepNames0)
    sweepVarValues1=sweepVarValues(sweepNames1)
    sweepVarValues2=sweepVarValues(sweepNames2)
    sweepVarValues3=sweepVarValues(sweepNames3)
     foreach(sweep0 sweepVarValues0
      foreach(sweep1 sweepVarValues1
       foreach(sweep2 sweepVarValues2
        foreach(sweep3 sweepVarValues3
         mosId=abs(leafValue(pv(mosDev "id") sweepNames0 sweep0 sweepNames1 sweep1 sweepNames2 sweep2 sweepNames3 sweep3 ))
         if(mosId>0.2u
          fprintf(fd,"Device:%s current:%f uA %s %f %f %f\n" mosDev,mosId/1u,sweep0,sweep1,sweep2,sweep3)
    close(fd)
    This works great as long as there is always 4 sweeps! 2 of them are model and temperature.
    The obvious question is how do you cope with less? I could check whether sweepNames# is nil and set all redundant sweepVarValues# to single element so redundant foreach only have single loop operation but then how will the leafValue() pick out the single oppoint with redundant sweep arguments?
    Its too messy to have an if not nil test for each foreach then a different length leafValue() and printf on each else.
