  3. spectre save restart
  • Views 19673
nnlt
nnlt over 7 years ago
hi,AE
I want to restart a tran simulation base on another tran simulation.  In the first tran simulation, I have set the savetime and savefile but I don‘t know how to restart the second simulation basse on the first simulation with the savefile?
Thanks.
  • CADcasualty
    CADcasualty over 6 years ago +1
    I'm hopeful this thread isn't too old to tack onto - I think my addition is relevant. The circuit I'm simulating contains an analog timer function that times out various states (e.g. end of power-up, auto…
    All you would do is run the second simulation with the recover parameter set to the filename that was saved from the first simulation. Provided that the stop time of the second simulation is greater than the time at which the first simulation saved the state, it will then run, starting from the time in the state file (there's no need to alter the start time of the second simulation; simply using recover is enough).
  • nnlt
    nnlt over 7 years ago in reply to Andrew Beckett
    i get it, thank you very much!
  • CADcasualty
    I'm hopeful this thread isn't too old to tack onto - I think my addition is relevant. The circuit I'm simulating contains an analog timer function that times out various states (e.g. end of power-up, auto-zero, acquire Vin etc.). The various timer times and durations are obviously subject to all the usual PVT variations. Is there a way to save state when such a timer event occurs? A possible example might be that a timer generated auto-zero pulse triggers a Verilog model that contains a directive like:
    $finish_current_analysis(0)
    after which a savestate could hopefully occur in my Ocean script.
