  3. Incorrect netlist of a circuit containing multibit instances...
  • Views 16841
Incorrect netlist of a circuit containing multibit instances from the analogLib (IC6.1.8)
Siliconsmith
Siliconsmith over 7 years ago
It happens that simulations cannot start because of errors found by spectre in 'multibit_pcell' during hierarchy flattening. The typical error message reads: ERROR (SFE-1997): "input.scs" line#: IABC.V0: parameter `dc': Cannot run the simulation because parameter 'a0' has been used but no value has been assigned to it.
I have discovered this issue can be solved in a test editor respectively in an ADE-L session, by manually launching "Recreate Netlist". But then, how can netlist recreating automatically be forced before any test simulation in ADE-XL?
    You need to contact customer support. I think you tried to do that via email (from a search I did with an identical error line), but the auto-reply tells you to log the case through support.cadence.com - please do that. We need to understand why the netlist is incorrect in the first place.
  • Frank Wiedmann
    Frank Wiedmann over 7 years ago
    Take a look at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXRwEAM. However, trying to find the root cause of the problem as Andrew suggested is probably still a good idea.
    Andrew Beckett over 7 years ago in reply to Frank Wiedmann
    Thanks Frank. That workaround is not something we'd want to encourage except in the case of working around a short-term bug, as it leads to a loss in performance by disabling the incremental netlisting... hence my request to work through customer support.
