  3. Configure VHDL design for simulation using VHDL Tool Bo...
  • Views 15358
Configure VHDL design for simulation using VHDL Tool Box
pyohayo
pyohayo over 7 years ago
In my simple setup I proceeded as follows:
  1. Created cell block_A (clock stimuli)
  2. Created symbol view for block_A
  3. In Symbol Editor ... "Create CellView from CellView", then select VHDL... cellview entity was created
  4. In Library Manager created new CellView (tolol VHDL-Editor) and named it vhdl
  5. Put block_A architecture in vhdl cellview
  6. Did pp. 1 ... 5 for block_B (device under test)
  7. Created schematic block_C, where I connected block_A and block_A
  8. In VHDL Tool Box selected block_C as top hierarchy
  9. Run simulation
  10. In SimVision design browser for block_A it's Ok - I can see internal signals, whereas for only ports are seen  ... and consequently simulation results are not relevant
  11. Then I tried ro create config view for block_C ... but couldn't properly setup it ... what view should I put in "View ro Use" for block_A and block_B ? Only one view is accepted, whereas both entity and architectury are needed.
Thanks in advance.
Pavel.
  • pyohayo
    Well ... the problem is resolved: there was a syntax error in  block_B    architecture.
    Before closing this topic can someone confirm ... or refute the following contents of config view for block_C:
    Cell                         View Found                           View to Use                    Inherited View List
    block_A                  vhdl                                         empty                               stimulus dataflow vhdl entity schematic symbol
    block_B                 vhdl                                          empty                              stimulus dataflow vhdl entity schematic symbol
    block_C                 schematic                              empty                               stimulus dataflow vhdl entity schematic symbol
    Thanks.
