  3. Strange behaviour of Virtuoso
  • Subscribers 133
  • Views 8896
FormerMember
FormerMember over 7 years ago
I'm using IC616 and IC617 with different design kits. Although I'm using similar configuration files, all works fine for some design kits but not for others. The errors I get are:
1. Library Manager is not opening automatically. I have to open it manually.
2. Custom Design Kit libraries and cells are not loaded. A folder named .ukcds5 should be created during the first opening of the DK (this folder contains a file for the cds lib definition) but this does not happen.
3. As a result, during the simulation with spectre, the following error is generated:
error found by spectre during circuit read-in.
ERROR(SFE-23): "input.scs" *** is an instance of an undefined model ***"
I can solve this issue (point 3) manually as suggested in many posts in this forum (e.g. https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/36703/error-sfe-23-undefined-model-or-subcircuit-modp-and-modn-and-error-sfe-874) but the general strange behaviour remain.
Currently, the DK ST BiCMOS55 and the ST BiCMOS9MW (vers 2.5) are working properly while the IHP SG13 and the ST BiCMOS9MW (vers. 2.8a) not. Of course, I've used the same installation procedure and I've also tested the DKs with both IC617 and IC616. Do you have any idea?
    Neither 1. nor 2. are default behaviour with Virtuoso (I've no idea what .ukcds5 is - it's nothing we produce). So these must be something that you're either doing in your environment or it's part of the ST UniCAD environment setup. You might want to talk to ST about this (although I guess that won't help with the IHP kit). Point 3. is related to the PDK setup as well - different kits take care of this either via some code loaded at startup, or via the libInit.il of the technology library; some kits don't set up the models at all and you have to do it yourself.
    The first could be solved by adding:
    ddsOpenLibManager()
    into your .cdsinit
  • FormerMember
    FormerMember over 7 years ago in reply to Andrew Beckett
    Thanks for the reply. Actually, the cdsinit file does contain the string you mentioned but the Library is not opening! There is a correlation between the wrong behaviour of the DK (points 2 and 3) and point 1.
