  3. Running Monte Carlo simulations on a statistical corner...
  • Views 18381
Running Monte Carlo simulations on a statistical corner in ADE XL
ddsab
ddsab over 6 years ago
I am attempting to run a mismatch only Monte Carlo simulation on a statistical corner in ADE XL on ICADV12.3, but I get the following error:
"ERROR (ADEXL-1751): The 'Monte Carlo Sampling' run mode requires at least one corner other than statistical corners to be enabled for tests."
What I am trying to do is take my two worst case corners from a process only Monte Carlo simulation, create two statistical corners, and then run mismatch only Monte Carlo on those corners to observe the overlap.  Is it not possible to run monte carlo on a statistical corner? Or do I have to dig through the weeds and create a fixed corner model file from the parameters in my worst case corner?  Any information is greatly appreciated.
Cheers,
Daron
    Daron,
    This is not possible (as far as I know). I'm not sure this necessarily adds any benefit over varying both process and mismatch together, but maybe it's useful - so if so, please contact customer support so that this can be requested as an enhancement request (I think I've seen similar requests in the past).
  • Sajith Sasidharan
    Sajith Sasidharan over 4 years ago
    Hello Daron,
    I am in need of the exact requirement as above. Please advise on any pointers.
    Sajith
    Andrew Beckett over 4 years ago in reply to Sajith Sasidharan
    Hi Sajith,
    This is still not possible, so I doubt Daron would be able to give you any pointers.
