  3. vmsUpdateCellViews : How to disable/override user pop-ups...
  • Subscribers 133
  • Views 3186
vmsUpdateCellViews : How to disable/override user pop-ups?
RakeshDama
RakeshDama over 6 years ago
When using vmsUpdateCellViews for the entire library on systemVerilog views, pop-ups for the HDL parser show up stopping the command from continuing. Is there a way to overcome this?
Rakesh.
  • RiadKaced
    RiadKaced over 6 years ago
    Hi Rakesh,
    Here are some SKILL variables you can setup in your Virtuoso session to avoid such pop-ups, you can copy theme from the following snippet link, which I also pasted below for convenience:
     vmsCrossViewCheck=nil
     schHdlCrossViewCheck=nil
     vmsUpdateSymbolAfterEdit = nil
     schHdlUpdateSymbolAfterEdit = nil
     schHdlEditAfterError = nil
  • RakeshDama
    RakeshDama over 6 years ago in reply to RiadKaced
    Hi Riad,
    Thanks for the response. I tried this and still couldn't get rid of the pop-up. The pop-up is related to:
    SystemVerilog *W,   WDPS: Parsing of systemverilog file produced warnings.
    Is there a way to avoid this ?
    The other ways I can think of is to disable verilog parsing
    Or to disable warnings.
    Rakesh.
    Andrew Beckett over 6 years ago in reply to RakeshDama
    Hi Rakesh,
    Set: vmsRunningInUI = nil before running the vmsUpdateCellViews() function. See How to disable HDL Parser Errors/Warnings dialog box?
  • RakeshDama
    RakeshDama over 6 years ago in reply to Andrew Beckett
    Thanks, Andrew. That works!
    -Rakesh
