  3. Copy pins as strongly connected
  • Subscribers 133
  • Views 16532
RVERP
RVERP over 6 years ago
If I copy a pin, then new pin is always weakly connected to the original one.
Is there a way to copy a pin so that the new pin is strongly connected with the original one?
    I don't think so (during the copy operation). What you can do is copy the pins, and then use Connectivity->Pins->Strongly Connected, and select the original and new pin (then hit escape). That will do it.
  • RVERP
    RVERP over 6 years ago in reply to Andrew Beckett
    Indeed, that will do the job for a single pin. But I have hundreds of pins an this function doesn't work on a batch of pins.
    Any other way to make a whole batch of pin pairs strongly connected at once, or do I need to script it?
    Andrew Beckett over 6 years ago in reply to RVERP
    No, it would need some code writing. The VLS XL Connectivity->Pin->Pin Connectivity Setting form won't help either as if you select all the pins and create a strong connect group, you end up with a single terminal with all the pin figures strongly connected which isn't what you want.
    I just wrote this which does what you want (I think). Just select all the pins that you want strongly connected, and it will convert them to be strongly connected (on their original terminals).
    /* abConvertSelectedPinsToStronglyConnected.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Sep 06, 2019
    Modified
    By
    Function to convert selected pin figures to be strongly connected.
    abConvertSelectedPinsToStronglyConnected([cv])
    SCCS Info: @(#) abConvertSelectedPinsToStronglyConnected.il 09/06/19.09:01:57 1.1
    *         abConvertSelectedPinsToStronglyConnected([cv])          *
    *   Convert all selected pins which are on the same terminal to   *
    * be strongly connected pins (keeping them on the same terminal). *
    *             Uses current cellView unless passed in.             *
    procedure(abConvertSelectedPinsToStronglyConnected(@optional (cv geGetEditCellView()))
      let((groupedPinFigures mainPin pinFigs origPin)
        ; Group the pin figures together to those on the same terminal
        groupedPinFigures=makeTable('groupedPins nil)
        foreach(obj geGetSelectedSet(cv)
          when(obj~>pin
            groupedPinFigures[obj~>pin~>term]=tconc(groupedPinFigures[obj~>pin~>term] obj)
        ; Now pick the first pin figure as the master, and move the pin figures
        ; of the rest to be on the same pin as the master, cleaning up any
        ; empty pins as we go
        foreach(group groupedPinFigures
          pinFigs=car(groupedPinFigures[group])
          mainPin=car(pinFigs)~>pin
          foreach(pinFig cdr(pinFigs)
            origPin=pinFig~>pin
            dbSubFigFromPin(origPin pinFig)
            unless(origPin~>figs
              dbDeleteObject(origPin)
            dbAddFigToPin(mainPin pinFig)
        t
  • RVERP
    Just tested this, works perfectly. Thank.
