  3. Liberate-max_transition
  • Replies 22
  • Views 27161
fengye
fengye over 6 years ago
Hi, everyone,
     When I use liberate to characterize some standard cells, like OAI21M0R at much lower voltage 0.3V. I set  such parameter with auto-index.
set_var max_transition 1.2e-7
set_var min_transition 1.0e-8
set_var min_output_cap 1e-17
However, I get the following error reminder
.........*Error* (char_library -auto_index) : the maximum load for OAI21M1R:Z is smaller than the specified min_output_cap (5.80844e-18F <= 1e-17F). This problem might be caused by insufficient drive strength or a max_transition value that is too small.
If I increase the max_transition value, the D-flipflop cannot meet the sequential timing. Did anyone meet this question?
  • Guangjun Cao
    Guangjun Cao over 6 years ago
    Hi Fengye,
    The min_output-cap is already very small. Are you sure your cell/model works fine at the give voltage? Does the error occur at all slew or just the max_transition? If increasing the max_transition works for some cells bu causes issue with other cells, you may have to use define_index command to change the slew or load table for other cells. You can get a template following the steps below,
    1. use -auto-index -trial options in char_libarary command and generate a template library, with the max_transition that is the maximum of all the transitions.
    2. use write_template to generate a template file
    3. adding define_index commands to change the slew or load table on cell/pin basis.
    Guangjun
  • fengye
    fengye over 6 years ago in reply to Guangjun Cao
    Hi, Guangjun, thanks for your reply.My cell can normally work at the given voltage 0.3V. I have simulated with Hspice. The error occur with the cell OAI21M0R, OAI21M1R,... The error information mainly concern about maximum load for the cell pin and min_output_cap. According to the reminder,if I increase the max_transition, the sequential cell D-flipflop will meet error for removal time.
    I don't know how to set proper index value for the cell, so I choose the auto_index. I remember you said,"min_transition is the minimum transition of the cells in your library. max_transition can be defined based on the actual design the library is used for. "
    Now, for this question, do I need to use define_index? How I can properly set the proper index value?
    Hope to receive your reply in your free time.
    Regars,
    fengye
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to fengye
    Hi Fengye,
    If you remove define the index table manually without -auto_index, does the error still occur?
    Guangjun
  • fengye
    Hi, Guangjun. If I remove the auto_index from char_library, and I add ""
    define_template -type delay \
    -index_1 {12 22 37 50 60 70 80 90 100 110 120 } \
    -index_2 {0.001 0.002 0.0035 0.005 0.0065 0.008 0.0095 0.011 0.0125 0.014 0.016 } \
    delay_template_11x11
    define_template -type power \
    power_template_11x11
    The new error occurs, like "ERROR (LIB-174): (char_library): The template 'delay_template_11x11' has an unreasonable '-index_1' slew value of: 100 nanoseconds which is greater than the sim_duration (1e-07 seconds). Update the 'define_template' and 'define_index' commands or the sim_duration in the Tcl script and rerun."
  • Guangjun Cao
    with the slew index table, the max slew is 120ns, which is bigger than your sim_duration of 1e-7s. You may sue sim_duration to increase its value. you may also need to set sim_estimate_duration=0
    Guangjun
  • fengye
    After I set sim_duration =1e-5s, and  sim_estimate_duration=0, there is no error. But all the value of the table is casual, which may lead inaccurate library. I still don't know why it cannot work with auto_index, and max_transion=120n
    fengye
  • fengye
    Hi, Guangjun,
    The following are some warnings for the auto_index setting.
    .WARNING (LIB-411): An estimated max load value of 3.17381e-16F will be used for slew: '3.80423e-07s' pin: 'Z' of cell: 'AOI21M0R' because the auto_index algorithm failed to determine the max load using bisection. This can occur when the inside-view algorithm cannot determine a valid vector. Add appropriate 'define_arc' commands specific to pin 'Z' and rerun.
    WARNING (LIB-411): An estimated max load value of 2.80317e-16F will be used for slew: '4.52601e-07s' pin: 'Z' of cell: 'AOI21M1R' because the auto_index algorithm failed to determine the max load using bisection. This can occur when the inside-view algorithm cannot determine a valid vector. Add appropriate 'define_arc' commands specific to pin 'Z' and rerun.
    How should I set the proper index value?
  • Guangjun Cao
    Hi Fengye,
    have you run Spectre simulation with the max slew and min/max load? do you see output transition within the range of slew index?
    guangjun
  • fengye
    Hi, Guangjun,
       Thanks for your reply! Happy mid-autumn day to you!  I run hspice simulation for OAI21M0R with input slew=120n, load= 1fF, the output rise transition=42.3ns, fall transition=30.5ns,(from 10% to 90%). If the load=16fF, the output rise transition=265ns, fall transition=91ns.
    The ouutput behaves the normal function. Is the maximum transition unreasonable?
    fengye
  • Guangjun Cao
    Hi Fengye,
    happy mid-fall day.
    I suggest you not to use auto_index in this case.
    guangjun
