  3. Liberate-max_transition
  • Replies 22
  • Views 27162
fengye
fengye over 6 years ago
Hi, everyone,
     When I use liberate to characterize some standard cells, like OAI21M0R at much lower voltage 0.3V. I set  such parameter with auto-index.
set_var max_transition 1.2e-7
set_var min_transition 1.0e-8
set_var min_output_cap 1e-17
However, I get the following error reminder
.........*Error* (char_library -auto_index) : the maximum load for OAI21M1R:Z is smaller than the specified min_output_cap (5.80844e-18F <= 1e-17F). This problem might be caused by insufficient drive strength or a max_transition value that is too small.
If I increase the max_transition value, the D-flipflop cannot meet the sequential timing. Did anyone meet this question?
  • fengye
    fengye over 6 years ago in reply to Guangjun Cao
    Hi Guangjun,
      If I don't use the auto_index, I don't know how to properly set up the concrete index value for delay and power. The index value maybe liner or squard. I don't find any reference about how to get proper index value. This is important for define_template and define_index. Can you give me some suggestions?
    fengye
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to fengye
    This is no absolutely right or wrong, when it comes to index table. As a general guidance, you may use the scaling factor below. when using it with -auto_index flow, you can copy/paste the lines to your template. If you do not use auto_index flow, it can also be sued as a guidance for defining index table.
    #these three variables must be defined by users, depending on design/PVTs
     max_transition 9.587e-10
    set_var min_transition 2.4e-12
    set_var min_output_cap 1.4e-16
    #do not change these, for simplicity
    set_var scale_tran_by_template 1
    set_var scale_load_by_template 1
    #these scaling factor factor can be changed based on preference. a value of "1" instruct the tool to use the max_transition that is defined above. for constraint slews, if a smaller max_transition is preferred for either pin/related_pin, reduce the last digit to less than 1, and the rest accordingly. mpw slews usually have the same table with const_refn. If a pin requires different index table from the default one defined in define-cell command, use define_index to override the default.
    set input_slews {0 0.007843 0.02363 0.05511 0.1181 0.2441 0.4961 1}              ;#for input slew
    set output_loads {0 0.007821 0.02346 0.05503 0.1182 0.2441 0.4961 1}
    set const_data {0 0.06672 0.2 0.4667 1}
    set const_refn {0 0.06672 0.2 0.4667 1}
    set mpw_rslew {0 0.06672 0.2 0.4667 1}
    define_template -type delay \
    -index_1 $input_slews \
    -index_2 $output_loads \
    delay_template_8x8
    define_template -type power \
    power_template_8x8
    define_template -type constraint \
    -index_1 $const_data \
    -index_2 $const_refn \
    constraint_template_5x5
    I hope this helps.
    Guangjun
  • fengye
    Hi, Guangjun,
       I'm so grateful for your reply. I copy the setting value to my template file and remove auto_index from the char_library. But there are many system errors, like
    *Error* (char_library) Failed to run 'cd /tmp/altos.vlsi-02.T20190914091458598475S0156198.7; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre +aps +spice -mt +liberate +rcopt=2 -vabsshort =log sim.lis +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D27885FE545A21AD943E01B8977A20DD879D11B8977A237E979D11B8977A237E924AD246A48416A9500003AA8 /tmp/altos.vlsi-02.T20190914091458598475S0156198.7/sim.sp >& /dev/null' on host vlsi-02.
    * Spectre exit code : 2(stop simulation because of Spectre error condition)
    LIBERATE - SYSTEM ERROR - could not execute command: cd /tmp/altos.vlsi-02.T20190914091458598475S0156198.3; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre +aps +spice -mt +liberate +rcopt=2 -vabsshort =log sim.lis +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D27885FE545A21AD943E01B8977A20DD879D11B8977A237E979D11B8977A237E924AD246D48466A9500003AB0 /tmp/altos.vlsi-02.T20190914091458598475S0156198.3/sim.sp >& /dev/null
    *Info* Simulation failed to complete. Restart the simulation in 5 seconds on host vlsi-02.
       I don't change other content. I don't know why the error occurs.
      Thanks again.
    Regars,
    fengye
  • fengye
    Hi, Guangjun
        I guess the spectre doesn't have any problem. If I provide min/max_transition, min_cap, just like the old, there is no system error. I find some solutions on the support about the system error. But this cannot be solved.
       fengye
  • fengye
    Hi, Guangjun,
        I try again with  auto_index, and the following paramter
    set_var max_transition 1.0e-7
    set_var min_transition 8.0e-9
    set_var min_output_cap 1.0e-17
       For this time, there is no other error. Do you think this can be adopted?
       fengye
  • Guangjun Cao
    Hi Fengye,
    The question is, are these expected with your design?
    Guangjun
  • fengye
    Hi, Guangjun,
        In fact, I don't know whether it's proper for my design. I don't know how to evaluate that. I still can use that for synthesis, but I still have a doubt whether it's right or not?
    fengye
  • anurans
    anurans over 6 years ago in reply to fengye
    max_transition for a completely new standard cell library depends on the constraints imposed by the cells in the library. Different designers specify it in different ways. One known method is to connect two registers (FF) of your cell library (if your library is designed from scratch) back to back and run them in the same clock. 10% of the maximum clock frequency the arrangement can operate is considered as the max_trans.
    The slew/load index range assigned to your cell should never violate min and max_trans. In your case you have to determine these two for the specific corner (i.e. 0.3V, TT, 25C) and -auto_index can handle the characterization for you.
    Anuradha
  • fengye
    fengye over 6 years ago in reply to anurans
    Hi, Anuradha,
    Thanks for your suggestion! In your proposed method for max_transition, whether the test two registers means the minimum drive strength in my cell library. There are many kinds of cell types, why the flipflop is used for max_transition? I still don't have the better way to deal with this issue.Can you give me more details?
    fengye
  • anurans
    "why the flipflop is used for max_transition?"
    If you refer to "set_var max_transition 1.2e-7", that's a unique value for your cell library per given corner. This definition does not depend on a particular cell of the library. However the slew/load values used for a unique cell (i.e. AOI22) should never lead that particular cell to violate the unique "min" / "max" transition values specified in the library. Sometimes the digital designer updates the max transition value based on the design.
    Another simpler method could be, to take the average of all maximum transitions for all the cells (when cells driving largest load). Indeed the values will change depending on the PVT corner.
    Anuradha
