  3. Liberate-max_transition
  • Replies 22
  • Views 27173
fengye
fengye over 6 years ago
Hi, everyone,
     When I use liberate to characterize some standard cells, like OAI21M0R at much lower voltage 0.3V. I set  such parameter with auto-index.
set_var max_transition 1.2e-7
set_var min_transition 1.0e-8
set_var min_output_cap 1e-17
However, I get the following error reminder
.........*Error* (char_library -auto_index) : the maximum load for OAI21M1R:Z is smaller than the specified min_output_cap (5.80844e-18F <= 1e-17F). This problem might be caused by insufficient drive strength or a max_transition value that is too small.
If I increase the max_transition value, the D-flipflop cannot meet the sequential timing. Did anyone meet this question?
  • fengye
    fengye over 6 years ago in reply to anurans
    Hi, anurans,
      Thanks for your reply. The Inappropriate max_transition may lead error for the timing constraints of  flipflop, like removal and recovery.
    ERROR (LIB-52): The constraint search failed to find a solution within the search range for arc of cell:'DFQRSXM1RA', r_pin:'CK', r_pin dir:'r', pin:'D', pin dir:'r', type:'hold_rising rise_constraint' when: (RB * SB), vector:'RRxxx'. This cell will be marked as failed and the constraint data will be set to: 1.0 (see constraint_failed_value). To debug, review the saved simulation results for deck: hold_19. Possible causes include: 'constraint_search_iteration_limit' too small; 'constraint_search_time_abstol' too small; estimated search range too large (see 'constraint_search_bound'). Modify the constraint parameters and rerun.
    However, if the max_transition is a bit small, the errror will occur like
    So, if there is no an appropriate method to evaluate the max_transition, it will be very difficult. In your suggestion, I need to simulate the maximum transitions for all my cells, I will try that again.
    Besides, for this transition setting, another error occurs , what the low voltage library(0.3v) and the high voltage library(1.2v) are both used for the same circuit in different domain. Transition violation occurs in the connection point with level shifter.
    Can you give me more suggestions?
    fengye
  • BarPouy
    BarPouy over 6 years ago
    Hi fengye
    Just I read your post. I assume your library operates in subthreshod regime. I'm also characterising a subthreshold library and I faced the same issue like you.
    The node I'm using is a ULP (not GP) technology with relative high threshold (near to 0.6V). To specify max_transition I run a Monte Carlo simulation on the extracted netlist of the largest bufx12 (not inv) in my library with a Load of 50fF, e.g. for TT-corner (25°) and vdd =0.4V. Then I measured the worst rise/fall transition of the output from 30% to 70%. This is in the mentioned corner 11.243 ns (fall). Actually this cell, with x12 strength, should drive 24fF, but I drived it for a fanout of 2.
    For the min_transition I selected for the same cell a load of 0.1fF and I measured the best rise/fall transition of the output from 30% to 70% and halved it. This is 0.3635 ns. For min_output_cap I set the same load of 0.1fF which I use to specify min_transition.
    I defined the index_1 / index_2 of all templates (delay, power and constraint) the same: # I'm not sure this strategy is optimal?
    {0 1/12 2/12 3/12 ... 12/12}  # actually this is in form of {0 0.08334 0.16667 0.25 0.33334 0.41667 0.5 0.58334 0.66667 0.75 0.83334 0.91667 1} referring to strengths x1 to x12 (as index_1)
    in case of index_2 the max load (here 50fF should be assigned to the last value of the index, i.e. '1' and the other loads should be assigned to the other values of the index appropriately (That is what I expected, but I'm not sure?)
    However I've an issue with the cells with the smaller than x12 strength. Some cells have, say, max 8 or 6 or even 2 strengths. What happen for such cell with such strategys? e.g for a D-FF there are only two strengths of x1 and x2. It is not possible to drive such load (I mean 50fF) with a D-FF of x1 in subthreshold regime. Therefore it does not make sense to assign such big load to the last value of the D-FF index. One Solution could be to specify for each cell class, i.e. the same count of strength, an index schema, e.g with max 9 values for the cell class with 8 strengths or only 3 values for D-FF. I'm not sure this is a good or even common strategy?
    How have you done?
    The other question is the simulation of the cell, even largest buf in SS / -40° /0.4V corner to specify max_transition. My cell has issue, i.e the time is too larg. Have you faced also this issue? Or, in other words have you specified also a corner of SS / -40° /0.3V for your library)?
    Thaking you in anticipation!
    BarPouy
