  3. Liberate : generate lib file for a level shift cell
  • Replies 19
  • Subscribers 132
  • Views 25385
fengye
fengye over 6 years ago
    Did anyone generate the lib file for a level shift with liberate? I don't know how to make some settings.
(1) For the following netlist,
.SUBCKT ls_cell IN OUT VDDH VDDL VSS
*.PININFO IN:I OUT:O VDDH:B VDDL:B VSS:B
MPM0 A net10 VDDH VDDH P_12_LLRVT W=100e-9 L=200n M=1
MPM1 net10 net10 VDDH VDDH P_12_LLRVT W=100e-9 L=60n M=1
MPM12 net069 net50 VDDH VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM11 net058 net50 net069 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM8 net071 OUT net046 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM7 net50 OUT net071 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM6 net046 OUT net072 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM10 OUT net50 net070 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM5 B A net10 VDDH P_12_LLHVT W=100e-9 L=60n M=1
MPM4 net072 OUT VDDH VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM9 net070 net50 net058 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MNM6 A In_not VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MNM8 net50 A VSS VSS N_12_LLLVT W=150e-9 L=100n M=1
MNM7 OUT B VSS VSS N_12_LLLVT W=150e-9 L=100n M=1
MNM3 In_not IN VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MNM5 B IN VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MPM3 In_not IN VDDL VDDL P_12_LLLVT W=4e-6 L=60n M=1
.ENDS
(2) the template is
define_template -type delay \
-index_1 {0.008 0.28 } \
-index_2 {0.01 0.3 } \
delay_template_2x2
define_template -type power \
power_template_2x2
define_cell \
-input { IN } \
-output { OUT } \
-pinlist { IN OUT } \
-delay delay_template_2x2 \
-power power_template_2x2 \
ls_cell
define_leakage -when "IN" ls_cell
define_leakage -when "!IN" ls_cell
# delay arcs from IN => OUT positive_unate combinational
define_arc \
-vector {XX} \
-related_pin IN \
-pin OUT \
ls_cell
# delay arcs from IN => Y positive_unate combinational
define_arc \
-vector {FF} \
-related_pin IN \
-pin OUT \
ls_cell
(3) the multi-voltage
set VDD_VALUE 1.20
set VDDS_VALUE 0.30
set_vdd VDDH ${VDD_VALUE}
set_vdd VDDL ${VDDS_VALUE}
(4) the error reminding
ERROR (LIB-88): (define_arc): Ignoring arc for cell: 'ls_cell', pin: 'OUT' X, related_pin: 'IN' X, vector: 'XX', pinlist: 'IN OUT' because of one or more invalid values (for example: value 'X' for signal 'OUT'). The valid values for the pin and related_pin are 'R' and 'F'. All other signals can use: '0', '1', 'R', 'F' or 'X'. Correct the Tcl and rerun.
(5) the input_volttage_range, output_voltage_range,how to get these, I need to use userdate to add these attribute.
I hope someone can help me .
Thanks a lot!
  • fengye
    fengye over 6 years ago in reply to Guangjun Cao
    Hi, guangjun,
     Thanks for your reply! After I make simulation with your suggestion, for the error arc, 'ls_cell', r_pin:'IN' r, pin:'OUT' r., the out cannot rise to the voltage VDDH. So, the measurement is failed. Maybe the circuit have error.
    When I change the new level shifter netlist, there is no error. But in the output lib file, there is no input/output voltage range for the input/output pin. Can you tell the voltagerange should be added by userdate or by some other liberate commands settings?
    fengye
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to fengye
    Hi Fengye,
    1. please show me the attribute of input/output voltage range in your reference library.
    2.please show me your command for defining these attribute. also, check the logfile to see if the attributes are failed to be applied.
    guangjun
  • fengye
    Hi,Guangjun,
    1. In my reference library, the attribute are "      input_voltage_range (0.8, 1.4);" and "      output_voltage_range (0.8, 1.4);"
    2. I don't define these attribute ,and I just define the VDDL and VDDH in the char.tcl. I guess these attribution should be added by userdata.
    fengye
  • Guangjun Cao
    Hi Fengye,
    you can certainly put the input_voltage_range in the user data file. set_attribute command is an alternative way. In this case, there might be a syntax issue--you have to give it a try. if set_attribute -cell ls_cell -pin {add_pin_name_here} input_voltage_range (0.8, 1.4) does not work, try "(0.8, 1.4)" or "\(0.8, 1.4\)" or \(0.8, 1.4\).
    Guangjun
  • fengye
    Hi Guangjun,
        Thanks for your reply! With your help, I have solved my problem. It's so kind of you.
    fengye
  • Guangjun Cao
    I am very glad to hear that!
    Guangjun
  • fengye
    Hi, Guangjun
        Recently, I find another question about the characterization of  level shifter. There is no leakage value in the generated lib file.  In the template,  I use "define_leakage -when "IN" ls_cell
    define_leakage -when "!IN" ls_cell" . Besides, in the char.tcl, "set_pin_vdd -leakage_add_to_supply VDDL -supply_name VDDL ls_cell IN ${VDDS_VALUE}" is added.
    But, in the lib file, it exhibits "    cell_leakage_power : 0;" and there isn't any leakage power calculation in the record file. Then I simulate the netlist with hspice, and the cell has leakage power. Did you meet this question?
       Regards!
      fengye
  • Guangjun Cao
    Fengye,
    I am on vacation now, so won't be able to answer your questions timely.
    You can try char_library -trial, without other options. Hopefully liberate can generate a linbrary with leakage arcs. Then, you can use read_library to read in this library and then write_template -verbose to generate a template. This template file should have define_leakage command.
    Generally, define_leakage commands have when conditions with both input and output, eg. For a cell with function as out=in, you will see two arcs with -when in * out, and -when !Out * !In.
    Hope this helps,
    Guangjun
  • fengye
    Hi, Guangjun,
        Thanks for your suggestion! I get the "define_leakage" for the level shifter.,
    define_leakage -when "IN*OUT" ls_cell
    define_leakage -when "!IN*!OUT" ls_cell
    or
     However, there still isn't leakage information. For one anther level shifter, the same setting can get leakage value. For my used level shifter, I make the dc simulation, and can get the leakage value, but it cannot get from the liberate. I guess the commands for "define_leakage" is correct, but still don't know the reason.
     I will try again! Hope you have a good time on your vocation!
    fengye
