  3. Liberate : generate lib file for a level shift cell
  • Replies 19
  • Views 25860
fengye
fengye over 6 years ago
    Did anyone generate the lib file for a level shift with liberate? I don't know how to make some settings.
(1) For the following netlist,
.SUBCKT ls_cell IN OUT VDDH VDDL VSS
*.PININFO IN:I OUT:O VDDH:B VDDL:B VSS:B
MPM0 A net10 VDDH VDDH P_12_LLRVT W=100e-9 L=200n M=1
MPM1 net10 net10 VDDH VDDH P_12_LLRVT W=100e-9 L=60n M=1
MPM12 net069 net50 VDDH VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM11 net058 net50 net069 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM8 net071 OUT net046 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM7 net50 OUT net071 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM6 net046 OUT net072 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM10 OUT net50 net070 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM5 B A net10 VDDH P_12_LLHVT W=100e-9 L=60n M=1
MPM4 net072 OUT VDDH VDDH P_12_LLHVT W=100e-9 L=500n M=1
MPM9 net070 net50 net058 VDDH P_12_LLHVT W=100e-9 L=500n M=1
MNM6 A In_not VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MNM8 net50 A VSS VSS N_12_LLLVT W=150e-9 L=100n M=1
MNM7 OUT B VSS VSS N_12_LLLVT W=150e-9 L=100n M=1
MNM3 In_not IN VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MNM5 B IN VSS VSS N_12_LLLVT W=2e-6 L=60n M=1
MPM3 In_not IN VDDL VDDL P_12_LLLVT W=4e-6 L=60n M=1
.ENDS
(2) the template is
define_template -type delay \
-index_1 {0.008 0.28 } \
-index_2 {0.01 0.3 } \
delay_template_2x2
define_template -type power \
power_template_2x2
define_cell \
-input { IN } \
-output { OUT } \
-pinlist { IN OUT } \
-delay delay_template_2x2 \
-power power_template_2x2 \
ls_cell
define_leakage -when "IN" ls_cell
define_leakage -when "!IN" ls_cell
# delay arcs from IN => OUT positive_unate combinational
define_arc \
-vector {XX} \
-related_pin IN \
-pin OUT \
ls_cell
# delay arcs from IN => Y positive_unate combinational
define_arc \
-vector {FF} \
-related_pin IN \
-pin OUT \
ls_cell
(3) the multi-voltage
set VDD_VALUE 1.20
set VDDS_VALUE 0.30
set_vdd VDDH ${VDD_VALUE}
set_vdd VDDL ${VDDS_VALUE}
(4) the error reminding
ERROR (LIB-88): (define_arc): Ignoring arc for cell: 'ls_cell', pin: 'OUT' X, related_pin: 'IN' X, vector: 'XX', pinlist: 'IN OUT' because of one or more invalid values (for example: value 'X' for signal 'OUT'). The valid values for the pin and related_pin are 'R' and 'F'. All other signals can use: '0', '1', 'R', 'F' or 'X'. Correct the Tcl and rerun.
(5) the input_volttage_range, output_voltage_range,how to get these, I need to use userdate to add these attribute.
I hope someone can help me .
Thanks a lot!
  • Guangjun Cao
    Guangjun Cao over 6 years ago
    Hi Fengye,
    you need to use set_pin_vdd/gnd to tell the tool the different pins and their associated power domains.
    Guangjun
  • Guangjun Cao
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V0000091BSOUA2&pageName=ArticleContent
    I found this article in our database.
  • fengye
    fengye over 6 years ago in reply to Guangjun Cao
    Hi, Guangjun,
    Thanks for your reply! The volatage net incudes VDDH, VDDL. I use "
    set VDD_VALUE 1.20
    set VDDS_VALUE 0.60
    set_pin_vdd -supply VDDH ls_cell OUT ${VDD_VALUE}
    set_pin_vdd -supply VDDL ls_cell IN ${VDDS_VALUE}
    set_var voltage_map 2
    ". But the results is different from a reference lib. There is still no input/outpt_voltage_map. Besides, the define_arc still have some problem.
    fengye
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to Guangjun Cao
    define_arc \
    -vector {XX} \  ==>change to RR
    -related_pin IN \
    -pin OUT \
    ls_cell
  • fengye
    Hi, Guangjun,
    Thanks for your reply! I change the define_arc and use the following setting "
    set VDD_VALUE 1.20
    set VDDS_VALUE 0.60
    set_pin_vdd -supply_name VDDH ls_cell OUT ${VDD_VALUE}
    set_pin_vdd -supply_name VDDL ls_cell IN ${VDDS_VALUE}
    The error reminder are as follows:
    ERROR (LIB-809): (define_arc): No vector was found for the arc of cell:'ls_cell', r_pin:'IN' r, pin:'OUT' r. This arc in the resulting library may not be correct. Update the 'define_arc' command and rerun.
    Performance statistics for ls_cell: Spectre cpu time = 26.0 seconds, total cpu time = 26.0 seconds, wall clock time = 50.0 seconds.
    ERROR (LIB-55): No valid vectors were found for the user provided define_arc for arc of cell:'ls_cell', r_pin:'IN', r_pin dir:'r', pin:'OUT', pin dir:'r', type:'combinational rise_transition', vector:'RR'. To debug, review the saved simulation results for deck: delay_1. Review port direction and vector values. Review spice deck(s) for valid delay measurements.
    fengye
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to fengye
    please use the saved deck to debug. check if the voltage levels are all correct.
  • fengye
    Hi,guangjun
     I check the file, and  I find "X1 IN OUT VSS VDDL VDDH ls_cell
    VVDDH VDDH 0 1.2
    VVDDL VDDL 0 0.6
    VVSS VSS 0 0" in the sim.sp . That means the voltage level is correct.
    For the error "ERROR (LIB-809): (define_arc): No vector was found for the arc of cell:'ls_cell', r_pin:'IN' r, pin:'OUT' r. This arc in the resulting library may not be correct. Update the 'define_arc' command and rerun.
    If I remove the define_arc for “RR”, there ia no error. So, this is because the error arc template?
    Besides, the attribute of "input/output voltage range" doesn't occur, this is needed to be added by using the userdate?
    fengye
  • Guangjun Cao
    1. please read the article with the link I sent you. you need to define "input_signal_level" attribute for level shifter.
    2. please do spice simulation, and check the waveform/level.
  • fengye
    I read the article you send me  and I use the following setting from the article reference
    set_vdd -cells ls_cell -attribute (std_cell_main_rail true) VDDL 0.6
    set_vdd -cells ls_cell -attribute (related_bias_pin vdds direction inout} VDDL 0.6
    set_pin_vdd -leakage_add_to_supply VDDL -supply_name VDDL ls_cell A 0.6
    set_pin_vdd -supply_name VDDH ls_cell Y 1.2
    set_attribute -cells ls_cell -pins {A} input_signal_level VDDL
    set_attribute -cells ls_cell -pins {A} related_power_pin VDDL
    The error occurs agiain!
    *Warning* (set_gnd) : Gnd supply VSS has already been set, overriding previous value to 0
    bad value "VDDL" for parameter
    voltage float () Voltage value
    while executing
    "OptDoOne descriptions state arguments"
    (procedure "OptDoAll" line 30)
    invoked from within
    "OptDoAll desc arglist"
    (procedure "::tcl::OptKeyParse" line 10)
    invoked from within
    "::tcl::OptKeyParse set_vdd $args"
    (procedure "set_vdd" line 1)
    invoked from within
    "set_vdd -cells ls_cell -attribute (std_cell_main_rail true) VDDL 0.6"
    I will simulate the spice according to your suggestion.
    Thanks again!
    fengye
  • Guangjun Cao
    these two lines have syntax error,
    please use {} .
