  3. Pad and Pad Frame
  • Views 18576
Pad and Pad Frame
jyoti kandpal
jyoti kandpal over 6 years ago
can anyone tell how to make pad and pad frame in gpdk 90 nm technology?, and what is the tolerance level for any circuit after post-layout simulation?
    I don't understand your questions (what do you mean by "make pad and pad frame"? I also don't understand what the second question is related to either).
    You're far more likely to get answers to questions if they are clear and provide enough context.
  • jyoti kandpal
    jyoti kandpal over 6 years ago in reply to Andrew Beckett
    Hello sir, sir, my first question is that I tried to make pad in gpdk 90nm but when I saw in the LSW window there is no pad layer so i ask how to draw pad and pad frame.
    and my second question is how much difference is acceptable between pre-layout and post-layout simulation value? I got a 13% difference between inverter pre-layout and post-layout values. Is this acceptable or not?
    Andrew Beckett over 6 years ago in reply to jyoti kandpal
    There's a layer called "Bondpad" - if that's what you mean. You may be better off using gpdk45 from http://pdk.cadence.com as this also has a standard cell and IO library and so that may be a better source to find pads (not sure what you mean by "pad frame").
    As for the difference between pre-layout and post-layout, that will depend on the design, how good your layout is, and what is acceptable to you. I can't tell you what is acceptable to you, since I don't know!
