  3. dspf_include accept spectre syntax?
  • Views 16113
yeh1
yeh1 over 6 years ago
Looking for a way to use dspf_include to accept spectre syntax (.scs file). Also, where is dspf_include documented?
    Why would you use dpsf_include to accept a spectre file? It's specifically for DSPF, not for including spectre syntax files. Generally post-layout extraction tools should be able to produce DSPF.
    For documentation, run (from a terminal):
    `cds_root spectre`/bin/cdnshelp &
    (this will start the help included in the spectre release stream) and then search for dspf_include.
  • yeh1
    yeh1 over 6 years ago in reply to Andrew Beckett
    I'm looking for a way to include a spectre .scs file and override the subckt definition in the main spectre netlist, just as dspf_include works now but to include a .scs, not a .spf. I think a config view would do this; I'm looking for a way without having to use a config view.
    Andrew Beckett over 6 years ago in reply to yeh1
    You can do it by creating a spectre text view and including that viewName in the view list when netlisting (if  you don't have a config), or picking the spectreText view as the view to use if you are using a config.
    There's no equivalent of dspf_include which takes the header from the net listed schematic, and stitches in the content from another subckt in a specified file.
  • yeh1
    Great, that spectreText works, thanks.
