  3. how to create own via in cadence software
  • Views 15166
jyoti kandpal
jyoti kandpal over 6 years ago
hello sir, is there any method to create own via in cadence (IC 6.15)? I know in the cadence there are custom vias that are available to make the layout design.
2).when I draw my layout design through custom via there is a cross sign above the via. what are the mistakes done by me?
    Yes, you can define custom vias in the technology file of the technology library you're using. Why do you need to create a custom via? It's preferable to use standard vias if possible.
    Very hard to know what you've done wrong when you haven't really explained what you've actually tried.
  • jyoti kandpal
    jyoti kandpal over 6 years ago in reply to Andrew Beckett
    when I draw the layout of my design i connect the one metal layer to another metal layer through custom via. In used Via shows a cross sign(means a wrong  symbol X). When I drag these via they show min-width and Min area related text. how can I resolve this issue?
    Andrew Beckett over 6 years ago in reply to jyoti kandpal
    I have no idea how to resolve this because it's really unclear what you're talking about. Please contact customer support.
