  3. Two part functional symbol in Virtuoso
  • Views 14904
svuser
svuser over 6 years ago
Does Virtuoso have method to support two part symbols? An example would be a relay with a switch and control symbol that is separated but bound to one functional model. This is supported in Allegro PCB designer.
    Not currently. There's some work under way to support split symbols, but it would be best if you contact customer support so that we can ensure your needs are covered by the implementation work going on.
