  3. Reading from a file in Verilog-A
  • Views 19481
Manev
Manev over 6 years ago
 Dear All,
To simulate the performance of an analog IC  design (using spectre) , I want to "pass" a specific, predefined, sequence of binary data. For this purpose, I have created a "memory" using VerilogA, which outputs bits at each clock cycle. The example bellow is only for 1 bit. The idea is to load the data sequence from a separate file.
// VerilogA for RTL, memory, veriloga
`include "constants.vams"
`include "disciplines.vams"
module memory(clk, out);
input clk;
output out;
electrical out, clk;
parameter real vtrans = 0.45, high =0.9, td = 2p, tr=2p, tf = 2p;
integer fileHandle;
integer decimal_output;
integer captured_data;
integer x;
analog begin
@ (initial_step)
fileHandle = $fopen("~/bit0");
@ (final_step)
$fclose(fileHandle);
@ (cross (V(clk) - vtrans,+1)) begin
decimal_output = $fscanf(fileHandle,"%d", captured_data);
x = ( captured_data > vtrans);
end
V(out) <+ transition( high*x,td, tr, tf );
end
endmodule
The issue is that, after building, I get the following error in the "Parser Error/Warnings" window:
memory.va (/...../memory.va)
ERR741 [30:27]: Digital or unknown system function '$fscanf' found in analog
block.
</...../memory.va> : Failed with errors (1).
Do you have any toughs on this?
Virtuoso version IC6.1.7-64b.500.23
  • Saloni Chhabra
    Saloni Chhabra over 6 years ago
    I tried compiling your code at my end, and it does without any issues. Can you check what Spectre/MMSIM version are you using?
    Saloni
  • Manev
    Manev over 6 years ago in reply to Saloni Chhabra
    Hello Saloni,
    For some reason, spectre -W cannot be recognized as a command, but I found the version in the spectre.out log file after running a simulation:
    Spectre (R) Circuit Simulator
    Version 17.1.0.515.isr12 64bit
    Veselin
  • Saloni Chhabra
    Saloni Chhabra over 6 years ago in reply to Manev
    I cannot really see where is the problem could be. Can you run your verilogA code compilation on the command-line? It's explained on the link below:
    https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=1815796
     Please contact customer support so someone can check your setup.. it's odd that spectre -W doesn't work.
    Andrew Beckett over 6 years ago in reply to Saloni Chhabra
    The error message is not a spectre error. My guess is that you have some other simulator integration which is intercepting the VerilogA compilation and it's that simulator that doesn't support the model. From a little guess (I can't see who you work for), I suspect this might be Mica (I've seen issues with that breaking the Verilog-A checking in Virtuoso). Maybe you can try by running without that integration in your environment? You might need to speak to the support within your organisation.
