  3. Different output results of a system with adding new ci...
  • Views 14564
Different output results of a system with adding new circuits
sajjadsabbaghi
sajjadsabbaghi over 6 years ago
Hello everyone,
I had a strange problem regarding my system simulation in Cadence. My Cadence version is IC6.1.4.485. I am working on the simulation of a high-frequency PLL-based Clock and Data Recovery these days. Today, when I simulated the basic system (all blocks are transistor level), everything was ok and my results were good, but when I added some digital circuits that they are nothing to do with the basic system the output of the system changes. It is very strange because the additional circuits are not connected to the basic system. Can anybody guide me to solve my problem?
Thanks.
    You didn't mention which simulator you're using (see the forum guidelines for info on how to write a good question), and you're also using an ancient tool version (I think at least 11 years old). That said, I suspect this is probably just that the additional circuitry is causing there to be more time steps in the analog solver, and those increased time steps could alter the time the takes for the VCO to start up and hence alter the lock time, and even alter how accurately the oscillator simulates. Without more info, it's really hard to be sure - but given that circuit simulators (such as spectre) solve the entire circuit as a whole, with a common tilmestep for the entire circuit, adding non-connected circuitry can still make a difference, especially if you have some kind of adaptive circuit like a PLL.
    I can't really tell you more though - there's simply not enough to go on here, and I'm having to do a lot of speculating!
