  3. Plotting temperature in a transient simulation
  • Replies 9
  • Views 23909
Quantum7
Quantum7 over 6 years ago
I am running ic6.1.7-64b.500.23 and i am using ADE XL.
I am changing dynamic parameter, a temperature, during transient simulation, and that works well for me. However, after sims are done and i plot signals, how do i plot temperature vs time?
already tried all save options, tried seeing if i can find temperature in results browser, no luck. ideas?
    See this post.
  • Quantum7
    Quantum7 over 6 years ago in reply to Andrew Beckett
    I seen that post already.
    I did:
    ADE XL-->Outputs-->Save All, then on the bottom there was "Save circuit information analysis" i added new raw:
    name=temp, what=all, enabled=yes
    sim ran, opened results browser, don't see temperature..
    Andrew Beckett over 6 years ago in reply to Quantum7
    That's not what I said - I mentioned there that you need to use the Save by Subckt tab. I thought that appeared during IC617, but it seems I was mistaken - it was added in IC618 ISR3.
    So for the version you're using, you'll have to use the approach taken in this post instead.
    The way you did it won't work. That's just saving a result database called "temp" from an info analysis, which is not what I was saying.
  • Quantum7
    OK, i created file "savetemp.scs", with one line "save temp"
    then i added and included it in ADE XL-->Setup-->Model Libraries, reran simulation. unfortunately still dont see temp, where am i supposed to plot it from? im checking results browser and don't see anything related to temp
    Look in the results browser, under the "tran" results. At the top level you should now see a signal called "temp" which you can plot.
  • Quantum7
    that is exactly where i am looking, and there is no "temp" to plot, there are all my signals etc, but nothing "temp" related.
    did i miss some intermediate step maybe?
  • Quantum7
    Alright i found my problem...i did it for default "nominal" corner, but im running some custom corners, all i had to do is add that file definition in the specific corner im running.
    nevermind, now with this method of manual file inclusion sim works and i see  "temp" in transient sims. thank you
    I realised after my previous post (I had a personal commitment this evening so couldn't reply sooner) that you might have been using corners in ADE XL and so the Setup->Model Libraries on the test would then get ignored.
    Another approach would be to specify the included file via Setup->Simulation Files - under the Definition Files entry. Then this will be included even when corners are defined, and would avoid you having to enter it for each corner.
  • Quantum7
    great, thanks a lot! noted.
