  3. plotting Smith charts
  • Replies 15
  • Subscribers 138
  • Views 31686
dzakharian
dzakharian over 6 years ago
I'm running an .sp analysis with a simple setup--port set to 100ohm, with 100ohm load.  I'm plotting results on a Z-Smith, which i thought should give me Re(Z)=1 (normalized)... but instead I'm getting something like 2e-12 as the prime center.  I don't understand why this is the case.  I'm relatively new to Smith charts, but I'm guessing the plot actually shows reflection coefficient, not the impedance?  If this is the case, how can I request an impedance plot?
I'm on version 6.1.8.
Many thanks in advance for your help,
David
    Andrew Beckett over 6 years ago in reply to dzakharian
    In IC618 you can arrange the graphs the way you want and then save it as a plotting template. That's the way to define the type and style of your plots - we decided against having a gazillion options to control how you want something plotted automatically.
  • ZoltanT
    ZoltanT over 6 years ago in reply to dzakharian
    I do not know. I am just a simple user, but I would look for it in ViVA's skill reference first, or wherever the marker syntax is described.
  • Moof
    Moof over 4 years ago in reply to Andrew Beckett
    I share the original poster's frustration.  Smith charts have a marking scale in Ohms (real and imaginary), markers read as jibberish to anyone slightly versed in microwave expecting the marker to be in similar units.  Competitor products all handle this, and have done so for decades.  A plot marked "50" at its center should not give a marker value of zero, full-stop.  While I realize the reflexive response to any bad behavior or bug in Cadence is to spew forth yet-another-skill-script, the real desired action is to acknowledge how badly wrong this marker behavior is, and then provide a timeline for addressing it.
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Moof
    You might want to take a look at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000ADwbXEAT
    Andrew Beckett over 4 years ago in reply to Frank Wiedmann
    In addition to Frank's suggestion, you might also want to look at slide 13 onwards in the IC618/ICADVM20.1 ISR21 What's New slides.
