  3. Unable to Import .v files with `define using "Cadence Verilog...
  • Views 6056
Unable to Import .v files with `define using "Cadence Verilog In" tool
Nader Fathy
Nader Fathy over 6 years ago
I am trying to import multiple verilog modules defined in a single file with "`define" directive in the top using Verilog In. The code below is an example of what my file contains.
When I use the settings below to import the modules into a library, it imports it correctly but completely ignores all `define directive; hence when I simulate using any of the modules below the simulator errors out requesting these variables.
My question: Is there a way to make Verilog In consider `define directives in every module cell created?
Code to be imported by Cadence Verilog In:
`timescale 1ns/1ps
`define PROP_DELAY 1.1
`define INVALID_DELAY 1.3
`define PERIOD 1.1
`define WIDTH 1.6
`define SETUP_TIME 2.0
`define HOLD_TIME 0.5
`define RECOVERY_TIME 3.0
`define REMOVAL_TIME 0.5
`define WIDTH_THD 0.0
`celldefine
module MY_FF (QN, VDD, VSS, A, B, CK);
inout VDD, VSS;
output QN;
input A, B, CK;
reg NOTIFIER;
supply1 xSN,xRN;
buf IC (clk, CK);
and IA (n1, A, B);
udp_dff_PWR I0 (n0, n1, clk, xRN, xSN, VDD, VSS, NOTIFIER);
not I2 (QN, n0);
wire ENABLE_B ;
wire ENABLE_A ;
assign ENABLE_B = (B) ? 1'b1:1'b0;
assign ENABLE_A = (A) ? 1'b1:1'b0;
specify
$setuphold(posedge CK &&& (ENABLE_B == 1'b1), posedge A,  `SETUP_TIME, `HOLD_TIME, NOTIFIER);
$setuphold(posedge CK &&& (ENABLE_B == 1'b1), negedge A, `SETUP_TIME, `HOLD_TIME, NOTIFIER);
$setuphold(posedge CK &&& (ENABLE_A == 1'b1), posedge B, `SETUP_TIME, `HOLD_TIME, NOTIFIER);
$setuphold(posedge CK &&& (ENABLE_A == 1'b1), negedge B, `SETUP_TIME, `HOLD_TIME, NOTIFIER);
$width(posedge CK,1.0,0.0,NOTIFIER);
$width(negedge CK,1.0,0.0,NOTIFIER);
if (A==1'b0 && B==1'b0)
(posedge CK => (QN:1'bx)) = (1.0, 1.0);
if (A==1'b1 && B==1'b0)
if (B==1'b1)
(posedge CK => (QN:1'bx)) = (1.0,1.0);
endspecify
endmodule // MY_FF
`endcelldefine
`timescale 1ns/1ps
`celldefine
module MY_FF2 (QN, VDD, VSS, A, B, CK);
inout VDD, VSS;
output QN;
input A, B, CK;
reg NOTIFIER;
supply1 xSN,xRN;
buf IC (clk, CK);
and IA (n1, A, B);
not I2 (QN, n0);
wire ENABLE_B ;
wire ENABLE_A ;
specify
if (B==1'b1)
endspecify
endmodule // MY_FF2
`endcelldefine
I am using the following Cadence versions:
MMSIM Version: 13.1.1.660.isr18
Virtuoso Version: IC6.1.8-64b.500.1
irun Version: 14.10-s039
Spectre Version: 18.1.0.421.isr9
  • StephenH
    StephenH over 6 years ago +1
    This question "belongs" to the Virtuosos team, so I'll move the thread into the appropriate forum.
    Andrew Beckett over 6 years ago +1
    This is a known issue, and there's a change request for it (it's not entirely simple to solve) - CCR One workaround is to set this before using the Verilog-In: envSetVal("ihdl" "createFileLink" 'boolean…
  • StephenH
    envSetVal("ihdl" "createFileLink" 'boolean t)
    This will mean that the code in the library is imported as a link to the original file - which will retain the `define. That may not be what you want, so another approach would be to use the command-line cdsTextTo5x utility to import the Verilog source (note, I didn't try this with code like this, but my understanding is that it also should solve the problem).
  • Nader Fathy
    Nader Fathy over 6 years ago in reply to Andrew Beckett
    Thank you Andrew! envSetVal("ihdl" "createFileLink" 'boolean t) worked fine.
    Nader Sh.
