  3. CDL Import to merge bus bits
  • Views 15092
noramirkh
noramirkh over 6 years ago
Dear experts,
From what I observed CDL import has no option to merge bus bits in a bus in generated schematic or symbol.
Could you please confirm if this is a case? Or there is some hidden option to achieve that?
Norayr
    Andrew Beckett over 6 years ago +1
    Hi Norayr, This is available on the File->Import->SPICE form (an entry labelled "Merge BusBits" on the Input Tab) as standard from IC6.1.8/ICADVM18.1 ISR11. It was also available under a UNIX environment…
    Hi Norayr,
    This is available on the File->Import->SPICE form (an entry labelled "Merge BusBits" on the Input Tab) as standard from IC6.1.8/ICADVM18.1 ISR11. It was also available under a UNIX environment variable since IC6.1.7 since 6.1.7.500.9 (IC6.1.7 ISR9) - for details, see spiceIn: How to merge individual bus bits back into buses in the imported schematic. Reference symbols with bus pins during spiceIn, where CDL has expanded ports
  • noramirkh
    noramirkh over 6 years ago in reply to Andrew Beckett
    Thanks a lot.
