  3. Run AMS simulation with ADE-L with import systemVerilogCustom_pkg...
  • Views 18862
Run AMS simulation with ADE-L with import systemVerilogCustom_pkg::*
christinep
christinep over 6 years ago
Hi Support,
I am running ADE-L simulation with Config view. One block is with SystemVerilog and another one is pure analog circuit with transistors.
In SystemVerilog, I need to import custom library (for example, systemVerilogCustom_pkg) so top level sv file include import cst_pkg::*; in the first line.
When a simulation is launched, I see following errors:
xrun: *W,OPDEPRREN: Command Line Option (-nclibdirpath) is deprecated. Use (-xmlibdirpath) instead.
file: /virtuoso/spice_dump/virtuoso/simulation/tb_digital_core/ams/config/netlist/.mapi//dummyMapi.vams
file: /virtuoso/aaa_christinep_test/digital_core/systemVerilog/verilog.sv
import systemVerilogCustom_pkg::*;
xmvlog: *E,NOPBIND (/virtuoso/aaa_christinep_test/digital_core/systemVerilog/verilog.sv,3|13): Package cst_pkg could not be bound.
input cst_additional_config_t cst_additional_config1,
xmvlog: *E,SVNOTY /virtuoso/aaa_christinep_test/digital_core/systemVerilog/verilog.sv,17|36): Syntactically this identifier appears to begin a datatype but it does not refer to a visible datatype in the current scope.
input clk_controller_config_t clk_controller_config1,
errors: 3, warnings: 0
xmvlog: *W,SPDUSD: Include directory /dump/virtuoso/ given but not used.
xmvlog: *W,NOTOPL: no top-level unit found, must have recursive instances.
Total errors/warnings found outside modules and primitives:
Searched this forum, it looks like compiler order issue, but not sure how I can solve it.
All cst_additional_config_t is defined in the systemVerilogCustom_pkg. I know these files are okay in terms of SystemVerilog Syntax because when I ran with VCS without Analog Portion, it worked.
Christine
  • christinep
    Hi If it is not proper for custom circuit forum, can you please direct me where would be fit? Thanks
    Andrew Beckett over 6 years ago in reply to christinep
    Christine,
    The main issue is that debugging this without being able to see the files you've got is hard (and time consuming as it would probably need quite a few back and forth questions).
    I would advise you to contact customer support - that's what it is for.
  • Majdo
    Majdo over 5 years ago
    Hi christinep,
    have recently posted a reply to similar topic take a look  at thread https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/46965/how-to-include-an-instantiated-verilog-cell-in-the-config-view-of-ams-simulation  .
    What I would suggest is to go with option 4 and make your own library of packages in this manner. You cane also use AMS options -> Run-time Library compilation Settings.
    If you have only couple of packages go ahead and preset directly in the AMS simulator options if you have multiple ones you create a file contain link to all packages that you would like to have. In case you have some hierarchy of the packages the last ( bottom)  in the hierarchy have to be compiled as first file on the line:
    MyPkgFile example:
    -makelib MyPkgLib
         pathtopkg/pkgfilelvl2
         pathtopkg/pkgfilelvl1
       pathtopkg/pkgfileX
    -endlib
    Include this file in the AMS digital simulator via -f MyPkgFile or -F MyPKgFile.
