  3. Is it possible to re-use generated DSPF when using Smartviews...
  • Views 14606
Is it possible to re-use generated DSPF when using Smartviews to reduce simulation time?
dontpanic
dontpanic over 6 years ago
Hi! I really like the advantages of the new smartviews. However, simulation time increases since each time I run a point Spectre seems to generate a DSPF from scratch, and for large cells this can take very long.
Is it possible to somehow tell Spectre/Assembler to "re-use" or "cache"  the generated DSPFs so as to avoid this re-generation time overhead? (Note: due to post-processing reasons, I use the "dummy.il" pre-run script trick to force independent directories for simulations).
...or any other suggestions as how I could achieve simulation times with smartviews as fast as with raw DSPFs?
Thanks and regards,
Jorge.
P.S. I am using spectre 19.1.0.373.isr7 with ++aps and +postlayout.
    Andrew Beckett over 6 years ago +1
    Hi Jorge, There's a CCR for this (it's internal). It would help if you reported this via customer support and asked for a duplicate of CCR 1869487 to be filed. Andrew.
    Hi Jorge,
  • dontpanic
    dontpanic over 6 years ago in reply to Andrew Beckett
    OK Andrew, I'll file a request for this!
    Thanks, Jorge.
