  3. ADE-L: how to add include file without using hard-coded...
  • Views 17695
ADE-L: how to add include file without using hard-coded paths
dontpanic
dontpanic over 6 years ago
Hi! Is it possible to tell ADE-L to include a file without needing to hard-code its path? This procedure works in Assembler, but fails in ADE-L:
    1. I put the file to include (say "input.scs") under the cell directory
    2. In the ADE-L state I define a variable with the path, to be resolved at netlisting time:
    spectre_include=strcat(dbFullLibPath(asiGetDesignLibName(asiGetSession(hiGetCurrentWindow()))) "/" asiGetDesignCellName(asiGetSession(hiGetCurrentWindow())) "/input.scs")
    3. In the model files window, I add an entry VAR("spectre_include") (Note: I need a variable because when adding the skill code directly here, it tries to interpret it as a model and section definition!)
The problem is that ADE-L doesn't resolve the Skill code and netlists this as follows:
Vdd=8.500000e-01 \
spectre_include=strcat(dbFullLibPath(asiGetDesignLibName(asiGetSession(hiGetCurrentWindow()))) \
"/" asiGetDesignCellName(asiGetSession(hiGetCurrentWindow())) "/input.scs") \
Vss=0 \
include "correct_path_to_my_cell/input.scs"
And even tough the model definition is resolved correctly, Spectre complains about the unresolved variable value:
Error found by spectre during circuit read-in.
ERROR (SFE-874): "input.scs" 41: Cannot run the simulation because syntax error `Unexpected quoted string ""/". Expected close parenthesis or comma' was encountered at line 41, column 4. Correct the syntax error and rerun the simulation.
ERROR (SFE-683): "input.scs" 41: Badly formed parameters statement.
Is there anyway to force ADE-L to resolve such variable? Or any other way to include a file without hard-coding its path?
Thanks and regards,
Jorge.
    Hi Jorge,
    Design variables in ADE L are not SKILL expressions, and Spectre itself doesn't understand SKILL so this is not going to work. If you use ADE Explorer, ADE XL or ADE Assembler I think it would work (you might have to tweak the expression a bit - I didn't try).
    However, how about this for a different approach which would also have the benefit of working with design management tools too. Instead of doing it this way, create a new cellView, mylib/includeBlock/spectreText (of view type "spectre"), with contents as follows:
    // "spectre" description for "mylib", "includeBlock", "spectreText"
    simulator lang=spectre
    // an empty subckt - we don't particular want anything in the design
    subckt includeBlock ()
    ends includeBlock
    // the stuff you wanted to include - here I added a second transient analysis, say
    tran2 tran stop=2u
    When you hit the "extract" icon (or File->Extract) it will prompt you to create a symbol with no pins. You can then instantiate this in your testbench, and it will then get included in the netlist with no need to do anything else...
    ShawnLogan over 6 years ago
    Dear Jorge,
    I am not sure if this may be related to your error, but the use of external include files in the netlisting process requires escaping a number of characters. The error message SFE-874 you included in your post suggested to me this may be part of the problem you are facing. I am wondering your path with its backslashes does not contain the required escape characters "\". This was recently discussed in the following post. Andrew provides a link in this Forum post with an additional article that may also be helpful.
    community.cadence.com/.../error-ossgld-18-and-not-able-to-run-simulation
    Most likely, Andrew or other experts have more insight than I as I am not familiar with the specific differences between the netlister used in Assembler (where your solution appears to work) and ADE-L. Nevertheless, as on one has responded yet, I thought this might be worth considering.
    Shawn
    ShawnLogan over 6 years ago in reply to ShawnLogan
    My apologies, Andrew has just responded!
    Shawn
