  3. Unable to change diode parameters when importing the CDL...
  • Replies 8
  • Views 20935
Unable to change diode parameters when importing the CDL netlist
OrangeHalo
OrangeHalo over 6 years ago
Hi all,
I am translating a netlist file to schematic using spiceIn in Virtuoso 617. The netlist is for a standard cell library in TSMC 180nm technology. After importing the netlist, I found that two parameters: diode area and pj is not translated properly. I searched the forum and found some threads, and I added *.DIODEAREA in the netlist. But the area was not changed. Now I have two questions:
  • How to modify the file, so that the diode area and pj in schematic can be changed according to the netlist.
  • In the layout of the cell, there are some width and length. But the netlist only provides area of the cell. How can I fill in the length and width of the diode in the schematic?
Here is a how the diode is defined in the netlist file:
*.DIOAREA
*.DIOPERI
.subckt ANTENNABWP7T I VDD VSS
DI3 VSS I dn 0.2037p
.ends
Here is the translated parameters for the diode:
Thanks in advance.
Best,
OrangeHalo
  • Quek
    Quek over 6 years ago
    Hi OrangeHalo
    Would you please check if you had already added an appropriate parameter mapping during spiceIn? E.g.
    devSelect := diode dn
    propMatch := dn
    propMap := model area abc
    Please go to "CIW: Tools->CDF->Edit CDF" and replace "abc" with the actual CDF name of "Diode_area" parameter.
    Best regards
    Quek
  • OrangeHalo
    OrangeHalo over 6 years ago in reply to Quek
    Thank you Quek! It really helped me out. But there is another problem:
    When the schematic and layout of the std cell lib are imported into Virtuoso, the layout size of a diode which is used to fix antenna problem is smaller than the minimum size in the schematic. This will account for LVS problems. How can I change the minimum value in CDF parameter so that I can match the layout to the schematic? Or do you have any other suggestion regarding this problem?
    Here are the figures:
    • Size of the diode in layout (It is a N+/Psub diode, the sizes are labelled as 0.42*0.485):
    • Size of diode in schematic editor (As you can see, the minimum length(width) is 450nm, which is larger the 420nm shown in previous figure):
    Best,
    OrangeHalo
  • Quek
    Quek over 6 years ago in reply to OrangeHalo
    Hi OrangeHalo
    This is a common problem after spice-in. CDL netlists sometimes only provide area/perimeter of diodes but LVS rule deck uses W/L for comparison against the layout. As the W/L of the schematic diodes are still using the default values, there will always be parameter mismatches. For such situations, you will have to modify the W/L of the schematic diodes manually. You can open up schematic properties form of the diode and change L from 450n to 420n.
    Changing CDF is not a good idea as it affect the entire PDK. It is better to just change it in the properties form.
    Best regards
    Quek
  • OrangeHalo
    Hi Quek,
    Thank you for you kind reply. But I cannot change W to 420nm, because the minimum value of L is set to be 450nm. When I change it manually, the CIW shows that "L is below minimum - setting to min". How can I fix this problem?
    Best,
    OrangeHalo
  • Quek
    Hi OrangeHalo
    Now this is strange. If the min value of L for dioden is 450n, why is the layout diode using 420n? Do you get any DRC errors for the layout of the diode?
    Best regards
    Quek
  • OrangeHalo
    Hi Quek,
    There is no DRC error in the layout. Actually according to the design manual, the minimum value of L is even less than 420nm. I just dont know why the minimum L of the diode is set to be 450nm.
    Best,
    OrangeHalo
  • OrangeHalo
    Hi Quek,
    Some update: I managed to solve the problem by uncheck a box named "Hard_constrain". I am trying to find out what does that represent for.
    Best,
    OrangeHalo
  • Quek
    Hi OrangeHalo
    That's great. Thanks for the update.
    Best regards
    Quek
