  3. How to copy the outputs setup and the Global variables in...
  • Views 17805
How to copy the outputs setup and the Global variables in the mastero into the ade-XL outputs setup and Global variables respectively
RFStuff
RFStuff over 6 years ago
Dear All,
Is there any way, the outputs setup and the Global variables in the mastero into the ade-XL outputs setup and Global variables respectively ?
Kind Regards,
    ShawnLogan over 6 years ago
    Dear RFStuff,
    I do not believe you can export Maestro view into any type of ADE-XL view. The instructions for converting an ADE-XL view into an Assembler view using a state file, if I recall, were quite clear that this is a one way path and cannot be reversed. This appears consistent with Andrew's response at URL
    community.cadence.com/.../assembler-possible-to-export-tests-as-ade-l-states
    from about a year ago. Having written this, I suppose you could export the Assembler outputs as a comma-separated variable file and try to import the csv file of outputs  into ADE-XL. This, of course, will not include the global variables.
    Shawn
  • RFStuff
    RFStuff over 6 years ago in reply to ShawnLogan
    Thanks a lot.
    Andrew Beckett over 6 years ago in reply to RFStuff
    I'd also ask why you're wanting to do this? There are lots of additional features in ADE Assembler which aren't in ADE XL (one of which actually is the ability to import/export global variables to CSV), so I can't see much point in moving back to ADE XL. If it is because you have existing ADE XL views, you can simply open them with ADE Assembler (from the library manager, you can do Right Mouse->Open With), and then you're in the "new world" products and get all the additional features.
