  3. Fatal error when use ADE L to simulate veriloga blocks.
  • Replies 11
  • Views 21669
HaolinCong
HaolinCong over 6 years ago
I am using 6.1.6 to do some design and I try to use some VerilogA blocks, for example the blocks in ahdlLib and some customized blocks, in my simulation. But it meets an error showing below. The error index number is ' ERROR (VACOMP-1008)'. It seams that cadence cannot compile the ahdlcmi module library. I have no idea what is that.  I highlight the error message with red. Thank you very much if anyone can help me.
Simulating `input.scs' on sahand at 9:56:19 AM, Thur Jul 16, 2020 (process id: 2391).
Current working directory: /home/home2/students/haolinco/simulation/test_veriloga/spectre/schematic/netlist
Command line:
    /opt/cadence/MMSIM141/tools.lnx86/bin/spectre -64 input.scs  \
        +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_53396_1 -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 2391
Loading /opt/cadence/MMSIM141/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /opt/cadence/MMSIM141/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
Loading /opt/cadence/MMSIM141/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /opt/cadence/MMSIM141/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /opt/cadence/MMSIM141/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Reading file:  /home/home2/students/haolinco/simulation/test_veriloga/spectre/schematic/netlist/input.scs
Reading file:  /opt/cadence/MMSIM141/tools.lnx86/spectre/etc/configs/spectre.cfg
Reading link:  /opt/cadence/IC616/tools/dfII/samples/artist/ahdlLib/and_gate/veriloga/veriloga.va
Reading file:  /opt/cadence/IC616/tools.lnx86/dfII/samples/artist/spectreHDL/Verilog-A/logic/and_gate.va
Reading link:  /opt/cadence/MMSIM141/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file:  /opt/cadence/MMSIM141/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link:  /opt/cadence/MMSIM141/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file:  /opt/cadence/MMSIM141/tools.lnx86/spectre/etc/ahdl/constants.vams
Warning from spectre during AHDL read-in.
    WARNING (VACOMP-2265): "$finish;<<--? "
        "/opt/cadence/IC616/tools/dfII/samples/artist/ahdlLib/and_gate/veriloga/veriloga.va", line 49: In Cadence Verilog-A, the $finish function always behaves as though the message level value is 0, regardless of the value you specify: The simulator does not report simulation time, location, or statistics about memory and CPU time usage.
Time for NDB Parsing: CPU = 94.71 ms, elapsed = 614.42 ms.
Time accumulated: CPU = 148.894 ms, elapsed = 614.434 ms.
Peak resident memory used = 66.4 Mbytes.
Created directory input.ahdlSimDB/ (775)
Created directory input.ahdlSimDB//3712_artist_ahdlLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/ (775)
Created directory input.ahdlSimDB//3712_artist_ahdlLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/Linux-64/ (775)
Compiling ahdlcmi module library.
    WARNING (VACOMP-2397): Compilation failed when using pipe build. Bytecode flow will be used for encrypted VerilogA, and normal file compilation will be used for unencrypted VerilogA.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//3712_artist_ahdlLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/Linux-64/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. Otherwise, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Error when elaborating the instance and_gate. Simulation should be terminated.
Time for Elaboration: CPU = 64.186 ms, elapsed = 9.7813 s.
Time accumulated: CPU = 213.243 ms, elapsed = 10.3959 s.
Peak resident memory used = 75.2 Mbytes.
Aggregate audit (9:56:30 AM, Thur Jul 16, 2020):
Time used: CPU = 214 ms, elapsed = 10.4 s, util. = 2.05%.
Time spent in licensing: elapsed = 129 ms.
Peak memory used = 75.2 Mbytes.
Simulation started at: 9:56:19 AM, Thur Jul 16, 2020, ended at: 9:56:30 AM, Thur Jul 16, 2020, with elapsed time (wall clock): 10.4 s.
spectre completes with 2 errors, 3 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
    Did you do what the error message suggested and look in the ahdlcmi.out file that it referenced to see if that gives any more information? Perhaps you can post the model and the content of that file here?
  • HaolinCong
    HaolinCong over 6 years ago in reply to Andrew Beckett
    Thank you for helping me. I tried to read the log file but it is a little bit hard for me to understand. I saw some unexpected data type messages. Here is the log file content as well as the block model I am using in the simulation. It is the 'and_gate' block from ahdlLib.
    ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB//3712_artist_ahdlLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/Linux-64/ for Linux-64 with optimize using gcc on Thu Jul 16 10:03:25 PDT 2020 [5.0]
    ahdlcmicompile: Generating makefile
    PATH:  /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/bin:/opt/cadence/MMSIM141/bin:/opt/cadence/MMSIM141/tools.lnx86/bin/64bit:/opt/cadence/MMSIM141/tools.lnx86/bin:/opt/cadence/IC616/bin:/opt/cadence/IC616/tools/bin:/opt/cadence/IC616/tools.lnx86/bin/64bit:/opt/cadence/IC616/tools.lnx86/bin:/opt/cadence/IC616/share/oa/bin:/usr/local/xictools/wrspice/bin:/usr/local/xictools/xic/bin:/home/home2/students/tingruli/cadence/installs/INNOVUS171/bin:/home/home2/students/haolinco/Tools/gmsh_4_2_2/bin:/home/home2/students/haolinco/Tools/inductex/ix_5_07_23_linux/bin:/home/home2/students/naveen/jsim-2.0e:/usr/lib/jvm/java-7-openjdk-amd64/bin:/home/home2/students/tingruli/cadence/installs/INNOVUS171/bin:/opt/cadence/installs/VMANAGER1903/tools.lnx86/bin:/opt/cadence/installs/VMANAGER1903/tools/vmgr/bin:/opt/cadence/installs/VMANAGER1903/tools/vmgr/admin:/opt/cadence/installs/VMANAGER1903/bin:/opt/cadence/installs/XCELIUM1903/bin:/usr/local/texlive/2014/bin/x86_64-linux:/opt/mentor/Sourcery_CodeBench_Lite_for_ARM_GNU_Linux/bin:/opt/mentor/Sourcery_CodeBench_Lite_for_ARM_EABI/bin:/opt/synopsys/hspice/O-2018.09-SP2-2/hspice/bin:/opt/synopsys/lc/O-2018.06-SP5-1/bin:/opt/synopsys/wv/O-2018.09-SP2/bin:/opt/synopsys/syn/P-2019.03-SP1-1/bin:/opt/synopsys/I-2013.12_SP1/ai_bin:/opt/synopsys/L-2016.06-SP1/bin:/opt/synopsys/lc/M-2016.12-SP3-1/bin:/opt/synopsys/syn/L-2016.03-SP5-8/bin:/opt/matlab/R2017a/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin:/opt/eclipse:/opt/synopsys/L-2016.06/bin:/opt/synopsys/hspice/M-2017.03-SP2-1/hspice/bin:/opt/synopsys/G-2012.06-SP1/bin:/opt/synopsys/H_2013.03/bin:/opt/synopsys/L-2016.06-1/bin:/opt/netbeans-8.0.1/bin:/opt/gurobi/linux64/bin:/usr/local/cuda/bin:/opt/mentor/questa_sim/bin:/opt/mentor/modeltech/linux_x86_64:/opt/cadence/INCISIV141/tools/bin:/opt/cadence/INCISIV141/vmanager/bin:/opt/cadence/INCISIV141/tools/vmgr/admin
    LD_LIBRARY_PATH:  /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/lib:/opt/cadence/MMSIM141/tools.lnx86/giganta/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/mdl/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/mmsim/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/inca/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/spectre/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/dfII/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/lib/64bit:/opt/cadence/MMSIM141/tools.lnx86/lib:/opt/cadence/IC616/tools/lib:/opt/cadence/IC616/share/oa/lib/linux_rhel50_gcc44x_64/opt:/opt/cadence/IC616/tools.lnx86/Qt/64bit/lib:/opt/cadence/IC616/tools.lnx86/dfII/lib/64bit:/opt/cadence/IC616/tools.lnx86/sev/lib/64bit:/opt/cadence/IC616/tools.lnx86/lib/64bit:/opt/cadence/IC616/tools.lnx86/lib:/opt/cadence/INCISIV141/tools.lnx86/lib/64bit:/opt/gurobi/linux64/lib:/usr/local/cuda/lib64:/usr/local/lib:/usr/local/culasparse/lib64:/usr/local/cula/lib64:/usr/lib/x86_64-linux-gnu:/usr/lib/:/home/home2/students/tingruli/cadence/installs/INNOVUS171/oa_v22.50.063/lib/linux_rhel50_gcc48x_64/opt:/home/home2/students/tingruli/cadence/installs/INNOVUS171/tools.lnx86/lib:/opt/gurobi/linux64/lib:/usr/local/cuda/lib64:/usr/local/lib:/usr/local/culasparse/lib64:/usr/local/cula/lib64:/usr/lib/x86_64-linux-gnu:/usr/lib/:/home/home2/students/tingruli/cadence/installs/INNOVUS171/oa_v22.50.063/lib/linux_rhel50_gcc48x_64/opt:/home/home2/students/tingruli/cadence/installs/INNOVUS171/tools.lnx86/lib
    /opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j33 -f GNUmakefile
    Cleaning ./obj/optimize/5.0
    rm -f -rf ./obj/optimize/5.0
    Compiling C file and_gate_func.c (optimize) with -O0
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -c and_gate_func.c -o obj/optimize/5.0/and_gate_func.o || rm -f -f obj/optimize/5.0/and_gate_func.o
    Compiling C file and_gate_DcFuncDerLoad.c (optimize)
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -c and_gate_DcFuncDerLoad.c -o obj/optimize/5.0/and_gate_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/and_gate_DcFuncDerLoad.o
    Compiling C file and_gate_DcFuncLoad.c (optimize)
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -c and_gate_DcFuncLoad.c -o obj/optimize/5.0/and_gate_DcFuncLoad.o || rm -f -f obj/optimize/5.0/and_gate_DcFuncLoad.o
    Compiling C file and_gate_TranFuncDerLoad.c (optimize)
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -c and_gate_TranFuncDerLoad.c -o obj/optimize/5.0/and_gate_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/and_gate_TranFuncDerLoad.o
    Compiling C file and_gate_TranFuncLoad.c (optimize)
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -c and_gate_TranFuncLoad.c -o obj/optimize/5.0/and_gate_TranFuncLoad.o || rm -f -f obj/optimize/5.0/and_gate_TranFuncLoad.o
    Compiling C file and_gate_cmi_c.c (optimize) with -O0
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include -I/opt/cadence/MMSIM141/tools.lnx86/cmi/include -c and_gate_cmi_c.c -o obj/optimize/5.0/and_gate_cmi_c.o || rm -f -f obj/optimize/5.0/and_gate_cmi_c.o
    and_gate_func.c: In function 'and_gate_ParamInit':
    and_gate_func.c:247: warning: floating constant exceeds range of 'double'
    and_gate_func.c:248: warning: floating constant exceeds range of 'double'
    and_gate_func.c:267: warning: floating constant exceeds range of 'double'
    and_gate_func.c:268: warning: floating constant exceeds range of 'double'
    and_gate_func.c:287: warning: floating constant exceeds range of 'double'
    and_gate_func.c:288: warning: floating constant exceeds range of 'double'
    and_gate_func.c:307: warning: floating constant exceeds range of 'double'
    and_gate_func.c:308: warning: floating constant exceeds range of 'double'
    and_gate_cmi_c.c: In function 'and_gate_pDC_Load':
    and_gate_cmi_c.c:599: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast
    /opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1933: note: expected 'void *' but argument is of type 'long int'
    and_gate_cmi_c.c: In function 'and_gate_pCompare':
    and_gate_cmi_c.c:651: warning: assignment makes integer from pointer without a cast
    and_gate_cmi_c.c:651: warning: passing argument 1 of 'memcpy' makes pointer from integer without a cast
    /usr/include/string.h:42: note: expected 'void * __restrict__' but argument is of type 'long int'
    and_gate_cmi_c.c:651: warning: passing argument 2 of 'memcpy' makes pointer from integer without a cast
    /usr/include/string.h:42: note: expected 'const void * __restrict__' but argument is of type 'long int'
    and_gate_cmi_c.c: In function 'and_gate_pGetMatrixPointers':
    and_gate_cmi_c.c:657: warning: assignment makes integer from pointer without a cast
    rm -f -rf and_gate_DcFuncLoad.c
    rm -f -rf and_gate_DcFuncDerLoad.c
    and_gate_cmi_c.c: In function 'and_gate_pAnalTranLoad':
    and_gate_cmi_c.c:699: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast
    rm -f -rf and_gate_TranFuncLoad.c
    rm -f -rf and_gate_TranFuncDerLoad.c
    and_gate_cmi_c.c: In function 'and_gate_pSaveRestart':
    and_gate_cmi_c.c:725: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
    /opt/cadence/MMSIM141/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1162: note: expected 'struct ahdlAnalogVar *' but argument is of type 'char *'
    and_gate_cmi_c.c: In function 'and_gate_pSaveRestartInst':
    and_gate_cmi_c.c:728: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
    rm -f -rf and_gate_func.c
    rm -f -rf and_gate_cmi_c.c
    /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O0 -m64 -fPIC -o obj/optimize/5.0/and_gate_libahdlcmi.so ./obj/optimize/5.0/and_gate_func.o ./obj/optimize/5.0/and_gate_DcFuncDerLoad.o ./obj/optimize/5.0/and_gate_DcFuncLoad.o ./obj/optimize/5.0/and_gate_TranFuncDerLoad.o ./obj/optimize/5.0/and_gate_TranFuncLoad.o ./obj/optimize/5.0/and_gate_cmi_c.o  -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
    ld: cannot find -lc
    collect2: ld returned 1 exit status
    gnumake: *** [obj/optimize/5.0/and_gate_libahdlcmi.so] Error 1
    ld: cannot find -lc
    and_gate verilog code:
    `include "discipline.h"
    `include "constants.h"
    // $Date: 1998/09/23 03:13:33 $
    // $Revision: 1.2 $
    // Based on the OVI Verilog-A Language Reference Manual, version 1.0 1996
    // and
    // -  and gate
    // vin1, vin2:    [V,A]
    // vout:    [V,A]
    // INSTANCE parameters
    //    vlogic_high = output voltage for high [V]
    //    vlogic_low  = output voltage for high [V]
    //    vtrans      = voltages above this at input are considered high [V]
    //    tdel, trise, tfall = {usual} [s]
    module and_gate(vin1, vin2, vout);
    input vin1, vin2;
    output vout;
    electrical vin1, vin2, vout;
    parameter real vlogic_high = 5;
    parameter real vlogic_low = 0;
    parameter real vtrans = 1.4;
    parameter real tdel = 2u from [0:inf);
    parameter real trise = 1u from (0:inf);
    parameter real tfall = 1u from (0:inf);
       real vout_val;
       integer logic1, logic2;
       analog begin
          @ ( initial_step ) begin
         if (vlogic_high < vlogic_low) begin
            $display("Range specification error.  vlogic_high = (%E) less than vlogic_low = (%E).\n", vlogic_high, vlogic_low );
            $finish;
         end
         if (vtrans > vlogic_high || vtrans < vlogic_low) begin
            $display("Inconsistent $threshold specification w/logic family.\n");
         end
          end
          logic1 = V(vin1) > vtrans;
          logic2 = V(vin2) > vtrans;
          @ (cross(V(vin1) - vtrans, 1))  logic1 = 1;
          @ (cross(V(vin1) - vtrans, -1)) logic1 = 0;
          @ (cross(V(vin2) - vtrans, 1))  logic2 = 1;
          @ (cross(V(vin2) - vtrans, -1)) logic2 = 0;
          // define the logic function.
          vout_val = (logic1 && logic2) ? vlogic_high : vlogic_low;
          V(vout) <+ transition( vout_val, tdel, trise, tfall);
       end
    endmodule
  • HaolinCong
    Thank you very much for helping me with this. I tried to read the log file. But due to my knowledge, it is a little bit hard for me to understand. I can only tell some message related to an unexpected data type. Here is the log file as well as the block model (and_gate from ahdlLib) I am using in the simulation. I think the forum stops me to posting long content, so I attached them below. Thank  you very much.
    Fullscreen ahdlcmi.out.txt Download
    ld: cannot find -lc
    ld: cannot find -lc
    Fullscreen veriloga.txt Download
    // $Revision: 1.2 $
    // and
    // -  and gate
    // vout:	[V,A]
    input vin1, vin2;
    output vout;
       real vout_val;
       analog begin
    	    $finish;
    	 end
    	 end
          end
       end
    endmodule
    Andrew Beckett over 6 years ago in reply to HaolinCong
    It appears that you're missing the 64 bit version of libc.so.N on your machine (probably /lib64/libc.so.6).
    This would be installed via the "glibc" package. Here's what it is on my machine (RedHat Enterprise 6.5):
    UNIX> rpm -q -f /lib64/libc.so.6
    glibc-2.12-1.149.el6_6.5.x86_64
    Check if there is /lib/libc.so.6 - if so, you may just be able to run Spectre in 32-bit mode instead. Check on the Setup->Environment in ADE - if you've turned on 64-bit mode for spectre, turn it off. Otherwise check if you have the UNIX env var $CDS_AUTO_64BIT set before you start virtuoso, if so tell me what it is (you can type getShellEnvVar("CDS_AUTO_64BIT") in the CIW (the main window that appears when you launch virtuoso).
  • HaolinCong
    Thank you. I can find the 'libc.so.6' file under /lib32/ folder only. But it doesn't exist in folder /lib/ and /lib64/ .
    And the env var CDS_AUTO_64BIT is set to be ' ALL'.  In the ADE setupt->environment, I didn't turn on the 64-bit mode. But I don't if the 64bit mode is till using for my CDS_AUTO_64BIT setting to ALL. I tried to set the CDS_AUTO_64BIT to 'NONE' by "setShellEnvVar("CDS_AUTO_64BIT=NONE")"  but not working still. Maybe because the way I set CDS_AUTO_64BIT is wrong.
    I will ask my group mate who is maintaining the server to install the 64bit vision glibc package. Or is there anyway to use the 32-bit instead?
    Thank you,
    I would expect changing CDS_AUTO_64BIT to NONE as you've done to work here. The other thing you could do is to go to Setup->Environment and add "-32" to the userCmdLineOptions field.
    You're using pretty old versions here, but I would expect that to work. Not sure whether the errors are different if you do this or not?
  • HaolinCong
    We have installed the 64 version package on server at folder /lib64/x86_64-linux-gnu. And according to the manager, the path is set to be the default path for searching the libc.so.6 . But I still meet the same error.
    Fullscreen 4048.ahdlcmi.out.txt Download
    ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB//3712_artist_ahdlLib_and_gate_veriloga_veriloga.va.and_gate.ahdlcmi/Linux-64/ for Linux-64 with optimize using gcc on Sat Jul 18 16:40:14 PDT 2020 [5.0]
    PATH:  /opt/cadence/MMSIM141/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/bin:/opt/cadence/MMSIM141/bin:/opt/cadence/MMSIM141/tools.lnx86/bin/64bit:/opt/cadence/MMSIM141/tools.lnx86/bin:/opt/cadence/IC616/bin:/opt/cadence/IC616/tools/bin:/opt/cadence/IC616/tools.lnx86/bin/64bit:/opt/cadence/IC616/tools.lnx86/bin:/opt/cadence/IC616/share/oa/bin:/lib32:/usr/local/xictools/wrspice/bin:/usr/local/xictools/xic/bin:/home/home2/students/tingruli/cadence/installs/INNOVUS171/bin:/home/home2/students/haolinco/Tools/gmsh_4_2_2/bin:/home/home2/students/haolinco/Tools/inductex/ix_5_07_23_linux/bin:/home/home2/students/naveen/jsim-2.0e:/usr/lib/jvm/java-7-openjdk-amd64/bin:/home/home2/students/tingruli/cadence/installs/INNOVUS171/bin:/opt/cadence/installs/VMANAGER1903/tools.lnx86/bin:/opt/cadence/installs/VMANAGER1903/tools/vmgr/bin:/opt/cadence/installs/VMANAGER1903/tools/vmgr/admin:/opt/cadence/installs/VMANAGER1903/bin:/opt/cadence/installs/XCELIUM1903/bin:/usr/local/texlive/2014/bin/x86_64-linux:/opt/mentor/Sourcery_CodeBench_Lite_for_ARM_GNU_Linux/bin:/opt/mentor/Sourcery_CodeBench_Lite_for_ARM_EABI/bin:/opt/synopsys/hspice/O-2018.09-SP2-2/hspice/bin:/opt/synopsys/lc/O-2018.06-SP5-1/bin:/opt/synopsys/wv/O-2018.09-SP2/bin:/opt/synopsys/syn/P-2019.03-SP1-1/bin:/opt/synopsys/I-2013.12_SP1/ai_bin:/opt/synopsys/L-2016.06-SP1/bin:/opt/synopsys/lc/M-2016.12-SP3-1/bin:/opt/synopsys/syn/L-2016.03-SP5-8/bin:/opt/matlab/R2017a/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin:/opt/eclipse:/opt/synopsys/L-2016.06/bin:/opt/synopsys/hspice/M-2017.03-SP2-1/hspice/bin:/opt/synopsys/G-2012.06-SP1/bin:/opt/synopsys/H_2013.03/bin:/opt/synopsys/L-2016.06-1/bin:/opt/netbeans-8.0.1/bin:/opt/gurobi/linux64/bin:/usr/local/cuda/bin:/opt/mentor/questa_sim/bin:/opt/mentor/modeltech/linux_x86_64:/opt/cadence/INCISIV141/tools/bin:/opt/cadence/INCISIV141/vmanager/bin:/opt/cadence/INCISIV141/tools/vmgr/admin
    ld: cannot find -lc
    ld: cannot find -lc
    ld: cannot find -lc
    ld: cannot find -lc
    Here I notice the log file, there is a ' -rpath,/usr/lib -WL,-rpath,/lib -s' . Does this mean the searching path was 're-pathed' to /usr/lib and /lib which are the wrong path ? Could this be the problem ??
    Thank you very much,
    Those paths are OK. On my functioning system, I get the same paths - I think they get translated to the 64-bit equivalents automatically.
    I realised it can't really be missing 64-bit libc because pretty much nothing will work if that's missing (I know, because I stupidly tried to emulate that problem by renaming the link /lib64/libc.so.6 - my advice to anyone, don't ever do that!). Having rebooted in a different virtual machine, mounted the disk of the first machine and fixed it, I'm now back - but I'm not making that mistake again.
    What does "/usr/bin/lsb_release -a" and "/bin/uname -a" output?
    Did you manage to get it working with spectre running in 32-bit mode?
    To be honest, this is something that would be much better dealt with via customer support, even though you're using an old unsupported version.
  • HaolinCong
    Sorry for late replying. I was trying several different ways these days.
    No, I could never make it working with 32-bit mode. I am also thinking maybe it's because the linux issue. I was told that cadence actually doesn't support the Linux distro we are using, and my group mate need to do something extra to make it work on our server.  I am considering to install a CentOS on my own machine and run cadence.
    We are using Debian Linux and here is the output given:
    No LSB modules are available.
    Distributor ID: Debian
    Description:    Debian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    Linux sahand 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2 (2020-04-29) x86_64 GNU/Linux
    Yes, unfortunately Debian has never been supported - and I don't have a machine I can experiment with to see what might be wrong. Clearly it's unable to find libc for some reason.
    So all I can suggest is that you install a supported OS distribution (or CentOS as being close enough to something supported).
