  3. How to disable the info SPECTRE analysis?
  • Views 15372
ZoltanT
ZoltanT over 5 years ago
How can I avoid generating the many info analysis by spectre when I run s simulation from the GUI (Assembler/Explorer)? I was not able to figure out by myself.
I've running lots of corners and the files I/O (writing in this case) takes up plenty of time relative tot he simulation. I know, that I do not need these analysis. They seem to be waste of time and harddrive space.
Thanks!
    You can turn these off from the Outputs->Save All form. Obviously they can be useful if you have expressions referencing any of the data, but if not, they can be safely turned off.
  • ZoltanT
    ZoltanT over 5 years ago in reply to Andrew Beckett
    Thanks! In hindsight it is easy to find. I have no idea why I haven't found them last night.
    Where can I find a little bit more information about the use of the different info statements? Especially in the GUI. In spectre manual they are just listed. I've used only oppoint, captab before.
