  3. Changing the height and width of a viva graph
  • Subscribers 133
  • Views 15880
wgtkan
wgtkan over 5 years ago
I would like to change the height and width of viva graph but It it doesn't seem to take effect after adding this in my .cdsinit
width
envSetVal("viva.graphFrame" "width" 'string "600")
; height
envSetVal("viva.graphFrame" "height" 'string "500")
I have also looked at these older posts:
https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/11245/how-to-set-a-size-for-the-waveform-window-while-using-ocean
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/30504/setting-up-used-defined-graph-properties
How can I change the height and the width of the wave graph? I also went into the graph property and changed the analog height and analog width but it is not changing the height and width.
My cadence virtuoso version is :
Version IC6.1.8-64b.500.9
Spectre spectre191
Thank you very much for your help.
    These settings control the size of the overall ViVA window. I've tried them and they work fine. I set them, opened a ViVA window, and the size was controlled (using Tools->Waveform if I use the "viva" executable for example).
    The analog width and height are to control the default size of an analog strip, and minimum height - they're not the same setting as this.
