  3. Problem in simulating an inverter using BSIMCMG
  • Views 13311
Engto
Engto over 5 years ago
Dear All,
I'm using BSIM CMG model for simulating GAAfet behaviour so I have created (by importing verilogA files) 2 different symbols for ntype and ptype transistors.
I managed to plot their transcharacteristics and everything is ok. However when i try to realize the inverter adding the ntype and ptype symbols created, the input/output characteristic is completely wrong. By ckecking the model parameters after simulations through calculator, i found that the problem is that both symbols used are recognized as "ptype" by cadence in the inverter schematic. This Is very strong since in the symbols created they are correctly setted by me as ntype and ptype by DEVTYPE model parameter.
Can anyone help me?
Thanks a lot.
      Not from so little information. I would suggest you contact customer support if you can't provide at least the:
      1. Spectre netlist (input.scs)
      2. VerilogA model files
      3. Which version of Spectre and Virtuoso you are using
      Even that may not be enough, but it may at least give some clues.
