  3. Techgen Error: Starting Triangle not defined
  • Views 14306
CasV
CasV over 5 years ago
HI all,
I am trying to generate a qrcTechFile using Techgen and my own ICT file. However, I have run into a problem. My first question is whether I am running Techgen correctly (I have never worked with Cadence before). I try to run the Techgen simulation with my ICT file as an input, is this correct or should I use a different file. If this is the case: which file?
When running "Techgen -si <ICTfile> " I get the following error statement:
Interconnect Capacitance Modeler Techgen64 Version s18.1.2132
Copyright (c) 2018 Cadence Design Systems, Inc.
ERROR: Link error, starting Triangle not defined!
ERROR: There is a error in 2d field solver during solution. Please contact
with developer.
ERROR (EXTNXC-31) : Exiting due to a fatal error reported by the operating
system's runtime environment:invalid data () at
(/vols/ssvcmbuilds1/ws/builds/builds_ext_1812_ext_cm/ext/src/libfem/src/fem_common.cpp
[68], void libfem_ERROR(FILE*, const char*, ...))
Error, process analyzing failed
Does anybody have an idea how to fix this error?
    Andrew Beckett over 5 years ago in reply to CasV +1
    Could be - I don't know without spending time checking. That's why I suggested contacting customer support (I really have not played sufficiently with Techgen to know how it behaves with incorrect ICT…
    This suggests that something is wrong with the consistency of the ICT file. I would suggest you contact customer support as seeing the data will make this easier to debug.
  • CasV
    CasV over 5 years ago in reply to Andrew Beckett
    Thank you for your reply! I am now using a test ICT file with just 3 layers and a VIA. However, since it is a test file the layers start from a specific height and have nothing in between the substrate and the first layer. Could this be the problem?
    Cas
    Could be - I don't know without spending time checking. That's why I suggested contacting customer support (I really have not played sufficiently with Techgen to know how it behaves with incorrect ICT files).
  • CasV
    I fixed the error with Techgen and am now able to both simulate and compile my ICT file. However, I do have some problems with running Quantus. Do you have any idea how to set it up with the Techgen compiled files?
    Cas
