  2. PSpice
  3. Creating and editing models
  • Subscribers 31
  • Views 16747
Mohammad Sadr
Mohammad Sadr over 5 years ago
Hi Friends
I needed an LM565 to simulate, but unfortunately, the software did not have that LM565, and I accidentally saw this code on the Internet!
But I do not know how to give this code to the software!
The code is available in the following file
8637.SUBCIRCUIT.pdf
I have another problem and that I do not know what the format code is ?! And that when I copied this code from this PDF I had to change it. Can you help me and tell me if the code in the file above is the same as the code I wrote below or not ?!
Thank You
code:
.SUBCKT LM565 1 2 3 4 5 6 7 8 9 10
C_C1 0 init 1u
R_R3 $N_0001 6 1.75k
R_R4 0 init 1g
R_R6 8 9 10g
R_R2 3 0 10g
R_R1 $N_0002 7 3.6k
E_E15 $N_0002 0 VALUE { V($N_0003, 0)+V(6,0) }
E_E1 $N_0003 0 TABLE { 0.68*V(2, 0)*V(5,0) } + ( (-0.68,-0.68) (0.68,0.68) )
G_G1 init 0 VALUE { (V(7,0)-V(6,0))*0.00001458/(R0*C0*(V(10,0)-V(1,0))) }
E_E13 4 0 VALUE {sin(6.28*(0.27/(R0*C0))*(time+(R0*C0/(6.28*0.27))*V(0,init))) }
E_E3 $N_0001 0 VALUE {0.126354*(0.7+V(1,0))+0.873646*V(10,0) }
.ENDS
    ShawnLogan over 5 years ago +1
    Dear Mohammad, Mohammad Sadr said: I have another problem and that I do not know what the format code is ?! And that when I copied this code from this PDF I had to change it. Can you help me and tell…
    Andrew Beckett over 5 years ago in reply to ShawnLogan +1
    Hi Mohammad, More importantly, knowing which tool you're actually trying to use this model in is pretty key. Given that this is a discrete component, I suspect you're probably wanting to use PSPICE,…
    Andrew Beckett over 5 years ago in reply to Mohammad Sadr +1
    OK, having seen your other post in this thread, your questions are about Orcad Capture (and hence Pspice) so I'll move this thread into the PCB Design forum as that's the best place for it. You should…
    0 ShawnLogan over 5 years ago
    Dear Mohammad,
    I am sorry, but your question(s?) is (are) not 100% clear to me. I think you are asking two questions.
    1. What netlist format is the code you provided in this post?
    2. Is this netlist provided in your post equivalent to that contained in the Adobe file for which you provided the URL?
    I will try to answer my "version" of your questions and hope I understand Mohammad...
    1. The netlist format is clearly SPICE. In order to use that file in a spectre based simulation, the following article will provide a step-by-step process to create a symbol for this netlist and include the SPICE formatted netlist in a spectre simulation. I have used the procedure successfully countless number of times.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXEGEA2&pageName=ArticleContent
    2.  It appears the netlist code you provided in your post is a copy of that shown in the Adobe file whose link you provided. If you read this article, it includes the clause "Teh SPICE netlist of developed model is:", which confirms that the code is in SPICE format. Given that your netlist is identical to that in the Adobe file, I have no reason to believe the two are different. I am not sure why you might think they are not the same - but perhaps I do not have a correct understanding of your question!
    Shawn
    0 Andrew Beckett over 5 years ago in reply to ShawnLogan
    Hi Mohammad,
    More importantly, knowing which tool you're actually trying to use this model in is pretty key. Given that this is a discrete component, I suspect you're probably wanting to use PSPICE, in which case the PCB Design forum would be more appropriate than the forum on Custom IC Design. The answers would be different, I'm sure - if we know, I can move the thread over to the PCB Design forum if that's more relevant.
    The format is actually PSPICE format (there may be other flavours of SPICE which it also works in, but this is an extension of Berkeley SPICE but the behavioural constructs look very PSPICE-like).
    If you were to include it in a spectre simulation, you'd need to use the "pspice include" on Setup->Simulation Files in ADE (just including it as a model file won't work), or using the links that Shawn shared, you'd ensure it was a pspice text view.
    There is a mistake in the code - the line for E_E1 has a "+" in the middle which shouldn't be there. In SPICE and PSPICE, a "+" at the beginning of the line is a continuation character, and simply is a way of indicating that the next line is a continuation of the previous. Since you've combined onto one line, that + shouldn't be there (Spectre complains because of this, and it's fine if removed).
    The model also refers to two global parameters R0 and C0 which I assume refer to the external restore and capacitor values connected to the VCO in Figure 2. So in ADE you'd need to define those as design variables.
    If you're using PSPICE however, other than fixing the + on E_E1, the setup would be different so that's why I'd direct you to somebody familiar with PSPICE who can give more directed advice.
  • Mohammad Sadr
    0 Mohammad Sadr over 5 years ago in reply to ShawnLogan
    Dear ShawnLogan
    Source Code: 7870.PHASE LOCKED LOOP BEHAVIORAL MODELING.pdf
    I'm really sorry, I'm not very professional and I spent a whole day understanding this PDF file and the code inside it and I was confused.
    Because I do not know how to use this code!
    But in order for you to better understand my question, I ask in a different way so that your time and mine are not wasted.
    I use this software:
    When I put the LM565 chip on the schematic from the library, I realized that it could not be simulated with this chip, or in other words, it did not have a file PSpice! Well, I searched the internet for this piece, but I did not find it, but I managed to find a PDF that has a code in it, and I have no familiarity with this code! And I do not know how to use it. How do I copy the code inside this PDF file? I mean, in some places this code went to the next line and I was confused, I do not know how to copy this code! That I do not have a problem in simulation! Because I am not familiar with the format of this code and I always use the graphical interface to simulate the circuit.
    I came across this text in an educational document and realized that this program is a subcircuit netlist. But I still do not know how to use this code snippet ?!
    Now I had to go and design this IC (lm565) in the software, I guessed to myself that maybe this code was given to the schematic of that chip! But I came across this page and got stuck here!
    So what is the best way or the fastest way that I can use this code and be able to deliver this circuit to our college teacher by next week on Monday! I just want this circuit to answer! I will do whatever you say so that this circuit will respond.
    THANK YOU
  • Mohammad Sadr
    0 Mohammad Sadr over 5 years ago in reply to Andrew Beckett
    Hi
    This was exactly my problem, when I copied the code I said to myself, is this + now for addition, or does it have another use ?!
    Because I saw this example in a document. And well, I'm not familiar with this code either, I just want my circuit to work, that's it!
    0 Andrew Beckett over 5 years ago in reply to Mohammad Sadr
    OK, having seen your other post in this thread, your questions are about Orcad Capture (and hence Pspice) so I'll move this thread into the PCB Design forum as that's the best place for it. You should also ideally speak to your College Tutor as they should be giving you some guidance on how to start...
