  3. To be able to print the "region" DC operating parameter...
  • Views 2353
To be able to print the "region" DC operating parameter of all the transistors in the design
sidm
sidm over 5 years ago
Hi All,
wish to request guidance on how to use AD-EXL expressions to be able to print the "region" DC operating parameter of all the transistors in the design in the output after DC simulation.
If there is any other method for this then I can try that as well.
I am using IC6.1.8
Any suggestions will be great help !
REGARDS
    ShawnLogan over 5 years ago
    Dear sidm,
    Have you seen this document?
    support.cadence.com/.../ArticleAttachmentPortal
    Page 32 and forward discusses the different techniques to print operating point parameters. "Region" is one of the operating point parameters as it indicates in the beginning of the document. I hope this helps!
    Shawn
  • sidm
    sidm over 5 years ago in reply to ShawnLogan
    Thanks for the information Shawn.
    ShawnLogan over 5 years ago in reply to sidm
    Dear sidm,
    Sure! I hope it provides the insight you need!
    Shawn
