  3. output format from Hspice simulation from ADE
  • Replies 9
  • Views 21433
cADEUser
cADEUser over 5 years ago
I am running Hspice as a simulator from ADE.  After setting everything the simulation works fine. But I can't see any waveform. I think Hspice does not generate pxfl format.
No waveform loaded.  Hspice generate tr0 file but it's not loaded in ADE.  Is there any way to view the waveform ?
    ShawnLogan over 5 years ago
    Dear cADEUser,
    I believe HSPICE can save data in fsdb format. ViVA supports a number of fsdb formats as shown in the On-line support article at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    Did you try that format?
    Shawn
  • cADEUser
    cADEUser over 5 years ago in reply to ShawnLogan
    Hi Shawn,
    I was trying to select the option that outpust fsdb. But when I choose the simulator as "Hspcie" that option is not available anymore from the "Output-->Save All"
    ShawnLogan over 5 years ago in reply to cADEUser
    Dear cADEUSer,
    I did not realize you were running HSPICE from ADE-Explorer (as opposed to running HSPICE). Perhaps you can include an HSPICE command to set the output format to what you want. A quick internet search suggests this HSPICE command may format the output in fsdb format.
    .option fsdb
    I do not run HSPICE from the Cadence interface, so I am not the best person to answer your question.
    Shawn
    I've not run HSPICE through the hspiceD interface for a while (I don't currently have access to licenses for testing the interface). The expectation is that HSPICE produces PSF format when run in ADE - are you getting these lines in the netlist?
    .OPTION
    + ARTIST=2
    + INGOLD=2
    + PARHIER=LOCAL
    + PSF=2
    Specifically the ARTIST=2 and PSF=2 lines? These are enabled via the Simulation->Options->Analog form, but should be turned on by default. Is there anything in the HSPICE log saying that these were problematic? I think there's an HSPICE license needed for the artist link, so maybe you don't have that?
  • cADEUser
    cADEUser over 5 years ago in reply to Andrew Beckett
    Hi Andrew
    I have those .OPTION but it is not generating psf format waveform
    I only see these files in the psf directory
  • cADEUser
    cADEUser over 5 years ago in reply to cADEUser
    There is no complain about option either
    Andrew Beckett over 5 years ago in reply to cADEUser
    I've no idea why this is not working. You may need to ask Synopsys why it is not producing the data requested...
    I can't see any recent reports of issues with this - unfortunately I can't check it myself, as I mentioned (always difficult when a third-party simulator is involved). You could also contact Cadence customer support to just check that there's nothing else obvious going wrong...
  • cADEUser
    Thanks Andrew. Do you know if there is any way to set the HSPICE binary location ( Simulator Path )  from ADE GUI ?
    No, the normal expectation is that you have "hspice" in your UNIX search path before starting Virtuoso.
    You can change the binary name using:
    envSetVal("hspiceD.envOpts" "simExecName" 'string "myhspice")
    (which could be the path to the executable). You need to do this before starting ADE, as far as I know - and if using multiple simulations in ADE XL/Explorer/Assembler, you'd need to add this to your .cdsinit
