  3. How to fix a corrupted schematic
  • Views 14541
jorgevdelacruzN
jorgevdelacruzN over 5 years ago
I have a problem with a corrupted schematic. I run oaScan to check the errors and I got the following log:
Tool:           oaScan              oaScan_p047 (22.50)
Running: oaScan -lib id_sis_c040_ana_pll_lib -libPath /home/ip_ana_workareas_2/kepler_ana_workareas/nxf49433/WS_210111/data/id_sis_c040_clock_control/id_sis_c040_ana_pll/OA/id_sis_c040_ana_pll_lib
Started: Tue Feb  2 11:08:34 2021
Cellview id_sis_c040_ana_pll_lib/id_sis_c040_ana_pll_bias/schematic_avt 'schematic':
ERROR: (OA-131): Corrupted database encountered: Unable to read design data from design id_sis_c040_ana_pll_lib/id_sis_c040_ana_pll_bias/schematic_avt. The long mapWindow cannot determine the byte-swap direction. The value 0x00000000 is an unexpected value.
NOTE: 1 error encountered that prevents the scan of this database.
No inconsistencies found in 111 databases
- found in 0 of 61 designs
- found in 0 of 50 DMDatas
Finished:       oaScan
Time elapsed:   0.94 seconds
CPU Time:       0.118541 seconds
System Time:    0.050658 seconds
Peak VM:        913408 bytes
Messages:       1 OpenAccess error, 0 OpenAccess warnings
I tried to repair it using -repair but I was not possible. Is there another way to recover this schematic view?
    Two recent (ish) posts on this: first and second. See the advice in those.
