  3. Current density check for layout design
  • Views 15692
Senan
Senan over 5 years ago
I want to check if my routing in the layout are well designed to carry the currents in the circuit and have no current density problem, it is kind of routing reliability check for layout
Thank you
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago +1
    You might want to take a look at support.cadence.com/.../articleattachmentportal
  • Frank Wiedmann
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    There is also the Virtuoso Electrically Aware Design tool (this is for in-design EM analysis) and Voltus-Fi XL tool too (a higher capacity signoff tool). I've made those links to the relevant RAKs.
  • Senan
    Senan over 5 years ago in reply to Frank Wiedmann
    Thank you very much Frank for your help
  • Senan
    Senan over 5 years ago in reply to Andrew Beckett
    Thank you very much Andrew for your help
